Installing mechanical fuel pump on 302 - Vintage Mustang Forums
post #1 of 15 (permalink) Old 08-04-2008, 08:09 PM Thread Starter
Are there any special "things" I should know about installing a mechanical fuel pump on a '68 302? Thanks
AMR66 is offline
post #2 of 15 (permalink) Old 08-04-2008, 08:14 PM
AzPete's Avatar
Make sure the arm goes under the cam lobe. It may put pressure on the pump that makes it difficult to hold in place while installing the bolts.
AzPete
USAF (Ret)
'07 GT Vert (The family car)
'66 Coupe (For fun)
Previously owned: Blue '66 Coupe, Red '66 Coupe, red '68 Coupe, Black '87 GT HO, Red '00 GT Vert
AzPete is offline
post #3 of 15 (permalink) Old 08-04-2008, 08:17 PM Thread Starter
So, the "arm" on the fuel pump should "allways" go under the cam lobe when installing the pump?
AMR66 is offline
post #4 of 15 (permalink) Old 08-04-2008, 08:18 PM Thread Starter
The instructions also say something about putting grease on the end of the arm?
AMR66 is offline
post #5 of 15 (permalink) Old 08-04-2008, 08:22 PM
AzPete's Avatar
If not,it will not work. Arm on pump must be pushed down to pump fuel.
Yep, always a good idea on the grease.
AzPete
USAF (Ret)
'66 Coupe (For fun)
AzPete is offline
post #6 of 15 (permalink) Old 08-04-2008, 11:46 PM
cmayna's Avatar
+1
'50 Chevy 1/2......'65 coupe/302/AOD......'68 fb/351c/T5Z
cmayna is offline
post #7 of 15 (permalink) Old 08-05-2008, 09:02 AM Thread Starter
Ok, makes sense! Thanks much!
AMR66 is offline
post #8 of 15 (permalink) Old 08-05-2008, 09:34 AM
If it's too hard to hold in place, rotate the engine just a bit to take some pressure off the fuel cam and it will be easier to hold in place.
gwstang is offline
post #9 of 15 (permalink) Old 08-05-2008, 10:12 AM
My '64 1/2 vert. Ordered May '64. D code 4 speed, handling package, caspian blue, accent group, Ford blue manual top.
'68 vert. driver. Owned since Apr '78. C code AT, AC, PS, P disc B, PT lime gold, standard black interior and top. NOS RF fender and left quarter.New top and folding glass.
slim is offline
post #10 of 15 (permalink) Old 08-05-2008, 07:32 PM Thread Starter
Just noticed something else in the instruction sheet. Note: On push rod driven pumps, make sure the pump lever is mounted under the push rod, if not damage can occur. Is there a push rod in there on a 289 or 302?
AMR66 is offline
post #11 of 15 (permalink) Old 08-05-2008, 08:54 PM
CompInnovations's Avatar
There is a plunger on the sbf fuel pump, GM's have pushrods. The plunger goes on the underside of the fuel pump eccentric
Competition Innovations-Member SAE
www.competitioninnovations.com
A Mullet isn't a hairstyle, a Mullet is a lifestyle!
CompInnovations is offline
post #12 of 15 (permalink) Old 08-05-2008, 10:18 PM
I'm confused by the term plunger. Guess I'd call It a lever!
slim is offline
post #13 of 15 (permalink) Old 08-05-2008, 10:24 PM
AzPete's Avatar
The flat thingy that sticks out of a small block Ford manual fuel pump must go under the round thing-a-ma-jig inside the hole you removed the old one from. Put something on the flat end to make it slippery.
Just kiddin......
AzPete
USAF (Ret)
'66 Coupe (For fun)
AzPete is offline
post #14 of 15 (permalink) Old 08-06-2008, 09:39 AM Thread Starter
Got it! I think. Thanks!!
AMR66 is offline
post #15 of 15 (permalink) Old 08-06-2008, 12:35 PM
68RCodeConv's Avatar
It is not a pushrod fuel pump.
John Bednorz
1967 Shelby GT350, dark green, 347 stroker, 5-speed, inboards, #2206
1973 Mustang Convertible, white/white, black stripes, Q-code (351C-4V), ram air.
1968 1/2 428 CJ convertible, R-code, red/deluxe red, auto, finally finished.
"If you find the car of your dreams, ignore the price guides and pay whatever you have to in order to get it."
68RCodeConv is offline
