Speedometer gear calculator? - Vintage Mustang Forums
post #1 of 7 (permalink) Old 08-14-2008, 09:08 PM Thread Starter
RyanG85's Avatar
Is there an easy way to figure out what speedometer gear I need? I've changed tire size and rear end gearing. I'm running 245/60R15 tires and 3.25 rear gears behind a wide ratio trans. This is on my 69 Mach 1. Thanks.
-Ryan
69 M Code Mach 1, 4 speed
65 Coupe
RyanG85 is offline
post #2 of 7 (permalink) Old 08-14-2008, 09:21 PM
cmayna's Avatar
What is the Outside diameter of your tires?
'50 Chevy 1/2......'65 coupe/302/AOD......'68 fb/351c/T5Z
cmayna is offline
post #3 of 7 (permalink) Old 08-14-2008, 10:39 PM
Send a message via AIM to Black_67stang
Here is a good web site that should be able to help you out. Speedo gear calculator
Zach
1967 coupe- Keith Craft 306 street/T5z with Pro 5.0. Arning Drop/ Bilsteins/ cut 720's up front and 4.5 mideyes out back. 13 inch Cobra discs
http://www.cardomain.com/ride/2236002/1
Black_67stang is offline
post #4 of 7 (permalink) Old 08-14-2008, 10:49 PM
70sportsroof's Avatar
The NPD catalog has a calculator printed on the same page where they list speedo gears.
Rebuilding a classic mustang is a reality check on your individual state of perfection.
70sportsroof is offline
post #5 of 7 (permalink) Old 08-14-2008, 11:18 PM Thread Starter
RyanG85's Avatar
26.55"
-Ryan
65 Coupe
RyanG85 is offline
post #6 of 7 (permalink) Old 08-16-2008, 12:28 AM Thread Starter
RyanG85's Avatar
Looking at the gear chart in CJ Pony, it is showing the same 16 tooth gear for both the 3.00 and the 3.25 unless theres a difference in F70-14 and FR70-14 tires? How can that be? The F70-14 tire is 24.78" tall, I'm running 245/60R15s that are 26.55" tall. I'm assuming with the bigger tires I would need maybe 1 tooth larger gear? I'm not that good with math, I just know my speed is about 15 MPH to fast right now and would like to get right with out buying and swapping a bunch of gears.
-Ryan
65 Coupe
RyanG85 is offline
post #7 of 7 (permalink) Old 08-17-2008, 08:56 PM Thread Starter
RyanG85's Avatar
Any ideas? Does the chart in NPD give you gears for different size tires or just the factory specs like CJ ponys?
-Ryan
65 Coupe
RyanG85 is offline
