Manual or power brakes ?
Sounds like the master cylinder piston may not be completely returning to the back of the bore.
If you have power brakes, make sure that the rod between the master cylinder and the booster has the correct amount of clearance (it's a really small amount...but there has to be a few thou clearance, at least).
You may have an adjustable push-rod in the brake pedal linkage. See if you have a turnbuckle-like adjustable pushrod...stick your head under the dash and look at the thing that is connected to the pedal itself, right by the brake light switch. If it's adjustable, make sure that there is a little bit of "free play" in the linkage.
"It's always better to be shot out of a cannon than to be squeezed out of a tube" - Hunter S. Thompson
I'm installing '68 disc brakes in my '67. I' ve been working to learn as much as possible about the swap. One thing I learned is about residual pressure valves included in master cylinders used on drum/drum vehicles.
The residual pressure valve keeps brake fluid pressure at the drum for quicker response. If you always had disc brakes and everything is original, this is not likely. However, you asked if there is anything with the m/c which would do this and a residual pressure valve would.
- Craig
Visit My Restoration Site - http://67TxStang.BlogSpot.com
1967 Mustang Coupe - 289 E-Street Heads, Comp XE256H Cam, Stealth Intake, & Holley Carb
+1
When I finally got mine road worthy, I spent an afternoon fine tuning the adj. rod till it was just right. If there is the slightest pressure on the plunger, you will have your symptoms.
First time out for 'longer drive' today. Entire brake system has been redone, as car had 'sat' for almost 30 years. I'll skip details and go to point:
Front brakes are evidently not totally releasing, which is keeping tension/friction on the front pads > heat > almost locking.
When they cool, the wheels will turn by hand, but barely.
I loosened bleeders, tightened, and they were fine.
Took it out, and they got tight again.
Pedal seems fine, and brakes operate fine, but it is not driveable as is.
Rear turned fine, so it is all front oriented.
Rebuilt calipers (Advance or wherever).
Service manual indicates more of an issue of the pistons not releasing in caliper sleeve?
If I'm not mistaken, I'm using original master cylinder with a rebuild kit in it, that had also been sleeved by Apple.
Is there anything in master cylinder operation that could lead to holding pressure on the fronts?
If so, the easiest thing to first replace is to put a different MC on it, as I have both a fully rebuilt orginal, as well as a parts store rebuild.
Thanks for thoughts....
All the ideas presented are good areas to check
out carefully.
As you mention yourself.....rebuilt calipers.
Don't discount that they may be playing into your
situation.
The square cut seal and the overall condition of
the seal's land in the caliper bore are the main
determining factors as far as how much the piston
returns back into the bore after you release the
brake pedal..... at least when you're purely
talking about the caliper, apart from the system
as a whole.
Akebono Corporation
Brake Systems Engineering Center
Farmington Hills, MI
- Douglas Adams
If the hoses are old they could have collapsed internally and are holding pressure.
John Bednorz
1967 Shelby GT350, dark green, 347 stroker, 5-speed, inboards, #2206
1973 Mustang Convertible, white/white, black stripes, Q-code (351C-4V), ram air.
1968 1/2 428 CJ convertible, R-code, red/deluxe red, auto, finally finished.
"If you find the car of your dreams, ignore the price guides and pay whatever you have to in order to get it."
Many years ago my 68 coupe with PDB would build up more and more pressure as I drove and wouldn't release the pressure after stopping, it ended up being a bad brake booster.
Just another possibility to add to your list of possible things to look at.
Good luck with the fix.
Bad brake booster? Would you explain this? Could have been the rod that goes with
the booster was improperly adjusted.
My '64 1/2 vert. Ordered May '64. D code 4 speed, handling package, caspian blue, accent group, Ford blue manual top.
'68 vert. driver. Owned since '77. C code AT, AC, PS, P disc B, PT lime gold, standard black interior and top. NOS RF fender and left quarter.New top and folding glass.
If your brake pedal is a little soft, you might still have air in the system. The air will expand with a little heat and cause pressure to extend the caliper pistons. You might consider more brake bleeding as the first step.
Doug
64.5 Convertible 260 V8, 87 El Camino, 66 Austin-Healey 3000, 2002 Jaguar XJ8, 2000 HD Road King
The rod was never adjusted and it was the original booster and MC in a low mileage car.
We changed the booster and problem was fixed.
It built up so much pressure the car wouldn't move.
I was literally stuck on the Ambassador bridge between Windsor and Detroit. Talk about a hefty towing charge.
That's what happened to me, but his problem could be completely different.
Next time they stick loosen the nuts holding the m/c to the booster ans see if the calipers release. If they do then the pushrod needs adjusted. Also check pivot points on any linkage for the booster for rust.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
