Front Frame Rail Repairs - Vintage Mustang Forums
post #1 of 8 (permalink) Old 11-09-2008, 08:47 PM Thread Starter
I’m looking for suggestions on repairing the front right frame rail on my ’66. Everything else on the frame rail looks solid up to the area in front of the shock towers. Looks like years of leaking batteries have taken its toll. Has anyone had success using partial frame patch panels or welding boxing plates around the frame?
Todd
http://i528.photobucket.com/albums/d...ngFrameRot.jpg
http://i528.photobucket.com/albums/d...angBattRot.jpg
'66 289 C4 Coupe, Signal Flare Red
ford53trk is offline
post #2 of 8 (permalink) Old 11-09-2008, 08:58 PM
rmousir's Avatar
you can buy a new frame rail and apron panel and weld them in or you can cut out the rust and patch them. Just depends on how much work you want to do and how you want it to look when you are finished. It is something you can certainly do your self. Good luck.
rmousir
1966 mustang
Check out my site:BUDGET RESTOMOD MUSTANG!
rmousir is offline
post #3 of 8 (permalink) Old 11-09-2008, 09:02 PM
Beach Bum
mike65's Avatar
My 65 Fastback had a rot spot in the l/s front frame rail about the size of a golf ball, I purchased a replacement section & cut off the piece I needed & welded it in.
Previous Mustangs,65 Fastback, 68 J code GT Coupe, 69 Coupe, & 70 Coupe.
Mike G.
2000 Ranger Extd Cab 4X4 (My DD) w/01 lights & grille.
2008 Escape
1999 Explorer Sport (Wife's DD)
1969 Mustang Coupe (Project)
MCA#-04549. MCA member for over 35 years.
"The times I've been mistaken, its impossible to say". - The Moody Blues.
mike65 is offline
post #4 of 8 (permalink) Old 11-09-2008, 09:09 PM Thread Starter
What gauge steel would you recommend for creating the frame patch panels? I'm not concerned with looks, more so with the structural integrity. The section that is rusted is the point where the lower strut rod attaches.
Thanks, Todd
post #5 of 8 (permalink) Old 11-10-2008, 12:15 AM
napaguy
Posts: n/a
If you search the mustang monthly web site they did a similair repair when they did the core support IIRC
post #6 of 8 (permalink) Old 11-10-2008, 08:23 AM
Send a message via AIM to timthechef
I just finished making some of the same repairs. I bought a piece of 1/8 inch steel cut it to the size I needed and welded it in. It's a little thicker than the original metal but how can that be bad? I bought the lower shock tower patches but ended up cutting them up and using them differently than they where designed for. Could have saved money just buying the steel.
1964 1/2 coupe with a 289 V8 automatic.
timthechef is offline
post #7 of 8 (permalink) Old 11-10-2008, 10:01 PM Thread Starter
Dave,
I found the link on mustang monthly regarding the frame repair. Exactly what I was looking for.
Thanks,
Todd
http://www.mustangmonthly.com/projec.../photo_18.html
post #8 of 8 (permalink) Old 11-11-2008, 07:16 AM
andrew3's Avatar
On my 67 coupe, I had the front driver side inner and outer rail sections rusted completely through at the bumper bracket location.
I cut off the whole front rail in front of the shock tower and trimmed a replacement frame rail section to fit. The thickness matched original nearly perfectly. It was actually surprisingly easy for a novice welder like myself.
1967 Mustang Coupe
Too many ideas to fit in one car
andrew3 is offline
