Help, 351W won't start! - Vintage Mustang Forums
post #1 of 14 (permalink) Old 01-10-2009, 12:35 AM Thread Starter
atsay714's Avatar
My 351W in my '70 stang stopped working altogether. Here's a summary of what happened.
It always had difficulty starting. Around 3-4 cranks to get it to turn over. It progressively got worse, and then it finally stopped working. One day, I kept trying to get it to start, cranking it a bunch of times, and the solenoid started smoking... So I immediately ran to my classic mustang supplier and got a new start solenoid and stuck it in. Sadly, however, my Windsor seems to have died.
Things to keep in mind: someone working on my car stole my brand new battery and replaced it with an incredibly old one. My resort is to hook the old battery up to a fully charged battery through jumpers, but it still doesn't start. Old batteries don't fry solenoids do they..
Can I get some ideas as to why my 351 isn't starting? I need as many ideas as I can get.
atsay714 is offline
post #2 of 14 (permalink) Old 01-10-2009, 12:47 AM
is it turning over at all? if not it could be the starter
---1969 Mustang Lime Gold!--
302 W, AFR 165's, Offenhauser Dual Port Intake, Holley 650 Spreadbore, Hooker Long tube Headers, Flowmaster 2 1/2" dual exhaust. T5 trans, 8" rear 3.55 lsd. Grabatrack suspension, Granada disk brakes.
Menorah 5 is offline
post #3 of 14 (permalink) Old 01-10-2009, 12:49 AM
Re: Help, 351W won't start!
mybe bad points/cond ?
jgstang is offline
post #4 of 14 (permalink) Old 01-10-2009, 12:50 AM
doug ford's Avatar
I'm wondering if you might have jumped time. If it progressivly got worse maybe the timing chain was stretching and got sloppy enough to jump a tooth?
Do you have spark when you crank it over? Do you have fuel when you pump the carb? Basically you need three things to make an engine run, air/fuel mixture, spark and timing. If you have spark and fuel I'd check the timing.
Doug
1968 modified fastback, aluminum 427 tunnelport 4 speed toploader
1968 coupe 289
'07 Shelby GT500, black with tungsten stripes
1995 SVT Cobra
1967 Fairlane GT 390 4 speed
http://www.cardomain.com/id/d_ford
Videos of my fastback at https://www.youtube.com/user/ohiofirelt?feature=guide
doug ford is offline
post #5 of 14 (permalink) Old 01-10-2009, 12:58 AM Thread Starter
atsay714's Avatar
it used to AT LEAST crank a bit, but now it doesn't even make a sound. i hear a lot about having a "strong" battery is needed to start an engine. is hooking my mustang's old battery up to a new battery through jumpers the same thing?
atsay714 is offline
post #6 of 14 (permalink) Old 01-10-2009, 01:04 AM
lethal289's Avatar
You can jump it through another battery, however, you will get more amps if the battery your are pulling power off of, was in another car running.
- Jake
lethal289 is offline
post #7 of 14 (permalink) Old 01-10-2009, 08:07 AM
if it wont do anything when the old battery is trying to crank with a jump try the good battery as the primary. check your battery cables both poitive and negative cable for corrosion. if in doubt buy new cables. smoke means drawing too many amps from either a bad starter or bad connection meaning bad/dirty cables ect. wes
mustang656man is offline
post #8 of 14 (permalink) Old 01-10-2009, 08:33 AM
Are the cables thick enough to carry enough power?
Bill
bk10s is offline
post #9 of 14 (permalink) Old 01-10-2009, 09:23 AM
Eliminate the old battery from the loop. Look down the carb while working linkage to ensure you're getting gas. Make sure you are getting spark. Check your timing and compression.
69' Mach 1 (under construction)
CandyAppleRed is offline
post #10 of 14 (permalink) Old 01-10-2009, 09:46 AM
Maybe you need to refill the solenoid with fresh smoke, since some leaked out before?
(Sorry, I just couldn't help myself...)
David
68 C-Code Coupe
Mustang_Charly is offline
post #11 of 14 (permalink) Old 01-10-2009, 02:06 PM
doug ford's Avatar
My bad, I misunderstood the question. I thought when you said you were cranking it the engine was turning over but not firing.
As others have said, replace the battery with a known good one and check cable connections. If it still won't turn over I would suspect the starter but since you said your battery was replaced with an old one that would be the first thing to check.
Good luck.
Doug
1968 coupe 289
1995 SVT Cobra
post #12 of 14 (permalink) Old 01-10-2009, 04:35 PM
musman's Avatar
, seriously put in a new battery, then try it, if nothing at all, starter must be bad, especially if it is not clicking after you've changed the battery..check connections of battery-solenoid-starter...start with that and then keep us posted...good luck
[color:red][/color]My 4 wheel lug nuts make more torque than your Honda!
1988 LX 5.0 Notch
1969 Mach1 351W Acapulco blue
2006 Ford E-150
2009 Ford Escape Limited 4WD
Daniel C
musman is offline
post #13 of 14 (permalink) Old 01-10-2009, 05:21 PM
I believe if you are jumping the battery and you turn the key and there is no sound it is the starter, but I may be wrong.
Turn on your lights see if they turn on at all, if they turn on your battery isn't the problem its your starter.
Someone correct me if im wrong.
post #14 of 14 (permalink) Old 01-10-2009, 05:27 PM
I had a similar problem once. The factory cables are a smaller guage than newer cars. The factory batteries had less cranking amps than newer batteries. Basically, the cranking melted the positive cable and wouldn't allow enough juice through to start the car. I would guess that you smoked the solenoid and maybe even melted the positive cable in the process. If the cable is melted, you will feel it. If the cable is smooth, then it didn't melt, but if you feel a depression anywhere, change the cable.
Like the others have said, try a fresh battery instead of trying to jump it. If it doesn't crank over, then check the starter. If that doesn't work, then check the timing. This is the order of least amount of work to most amount of work.
My Project: 1970 Mustang Convertible (currently stashed at my parent's house 1-1/2 hours away...ssssllllllooooooowwwwww progress)
Garage with my FX4 and 1970 Mach I
"That guy is so detailed that he would rebuild the engine to change the oil."
Cruise is offline
