1966 289 - How To Tell If Orig Motor? - Vintage Mustang Forums
post #1 of 23 (permalink) Old 01-31-2009, 08:06 AM Thread Starter
I have a 1966 convertible. How can you tell if the motor is original? Thanks.
Joe
jpb302 is offline
post #2 of 23 (permalink) Old 01-31-2009, 10:44 AM
AzPete's Avatar
I believe you need to pull the starter and get the numbers behind it. Then, compare that to the build date. The best you may get is that the engine was built at a proper time prior to the car so it would match as production moved forward.
AzPete
USAF (Ret)
'07 GT Vert (The family car)
'66 Coupe (For fun)
Previously owned: Blue '66 Coupe, Red '66 Coupe, red '68 Coupe, Black '87 GT HO, Red '00 GT Vert
AzPete is offline
post #3 of 23 (permalink) Old 01-31-2009, 12:20 PM
Re: 1966 289 - How To Tell If Orig Motor?
The car's VIN tells you which engine option it came with. The fifth digit is
the engine code. For '66 C is 289 2V, A is 289 4V and K is 289 4V high performance.
If the fifth digit is T the car was originally equipped with 200 6cyl.
To my knowledge you have no way to prove if the engine is the actual original.
As stated above you can determine if the production date is appropriate for
the build date of your car.
At some point K code engines were at least partially VIN'ed.
As far as I know proof that your (or any) car has it's actual original engine would
require continuous documentation seldom seen on even a high value historical vehicle.
My '64 1/2 vert. Ordered May '64. D code 4 speed, handling package, caspian blue, accent group, Ford blue manual top.
'68 vert. driver. Owned since Apr '78. C code AT, AC, PS, P disc B, PT lime gold, standard black interior and top. NOS RF fender and left quarter.New top and folding glass.
slim is online now
post #4 of 23 (permalink) Old 01-31-2009, 01:20 PM
You can reach a level a certainty. I have a 66 c code, I was in touch w/ the p.o.'s, and there is also a small metal tag on the intake manifold, this gives some other engine info. If this has made it for 43 years it is a good sign the engine has not been fiddled with too much. There is another tag on the carb too....
1966 Mustang Coupe
83,000 original miles,original engine, tranny, rear diff,
power steering,springtime yellow
originally a C-code, addded A-code intake, Autolite 4100, dual exhaust.
New leaf springs, KYB shocks, front coils,pertronix ign., thinking about dong a GT clone....
lleno is offline
post #5 of 23 (permalink) Old 01-31-2009, 01:30 PM
I agree but! I've rebuit my carb and put the tag back on. If I removed the manifold
I'd put the tag back on...you know where I'm going. If I replaced the short
block I'd put the tags on that were there to start with...maybe that's just me!
slim is online now
post #6 of 23 (permalink) Old 01-31-2009, 03:31 PM
frdnut's Avatar
I bought a very original looking 390 out of a T-bird once at a wrecking yard..It had all of the original metal tags in place and the proper casting #s and date code on the intake..A few years later I tore it down for a rebuild and discovered a 352 block and bottom end!..I guess somewhere over the years the top end complete with tags was swapped onto a different engine....Anyway my point is I never assume anything anymore..
68 J code sprint, 408W
11.47@123.35mph in street trim.
frdnut is offline
post #7 of 23 (permalink) Old 01-31-2009, 05:12 PM
I was lucky enough to have contact with the original owner and my car is virtually untouched, which is what I wanted when I went looking for my mustang. I have since realized that I was very lucky in that my car was driven very easy, never beat on. It does need most of the rubber replaced...
1966 Mustang Coupe
lleno is offline
post #8 of 23 (permalink) Old 01-31-2009, 05:19 PM
franklinair's Avatar
When did Ford start stamping the VIN on the top of the block, aft of the intake manifold?? (As with my 1968 302 4V)
Neil Hoppe
1968's: Best of the Best:
1968 GT/CS J Code
franklinair is offline
post #9 of 23 (permalink) Old 01-31-2009, 05:31 PM
My motor has the assembly date stamped on it in a few places. One place is on the oil pan gasket surface near the back. The other is on a flat portion of the block right below the head on the driver side. Mine has 7D17 stamped in both locations. Not sure if all were stamped in this manner but it can give you an idea without the need to remove the starter.
Link
- Craig
Visit My Restoration Site - http://67TxStang.BlogSpot.com
1967 Mustang Coupe - 289 E-Street Heads, Comp XE256H Cam, Stealth Intake, & Holley Carb
67TXStang is offline
post #10 of 23 (permalink) Old 01-31-2009, 10:12 PM
Neil Hoppe
They were mandated to start stamping VINs in the block in 1968; I believe it was part of the Motor Saftey Act of 1968 (or whatever it was called). Ford did stamp *some* cars before that, but mainly hi-perf stuff.
The squirrels in my head have spoken.
Cobra 5.0L & AOD swap, here we come.
gotstang is offline
post #11 of 23 (permalink) Old 02-01-2009, 08:32 AM
For what it's worth the 60's FE motors had 352 cast into them,So maybe your engine was original?
EastCoastClassic is offline
post #12 of 23 (permalink) Old 02-01-2009, 10:32 AM
Huckmag's Avatar
This is basic & old hat for most of us, but let's back track a little in case the OP isn't aware.
Ford used casting #'s starting with B in the 50's, C in the 60's, D in the 70's. (you see the pattern). The second digit was a number for the year in the decade. C6=1966, D2=1972 etc.
Many parts could have a casting number/part number that seems incorrect, ie too early by 1, 2, 3, or more years. This many not be a problem as many parts were cast/made and used on later cars.
What you look for are #s later than the production year of the car. They would very likely not be original.
Also, concerning 352, that was a truck engine, but don't fret. I had the same fear 20 years ago when I saw that on my 428CJ block. FE engines of that era all had that 352 cast into the block. It's scared the bejeezus out of countless car owners!
Darren
'69 B code Sportsroof Restomod in Progress. Factory AC, PS, PB, DLX int, fold down, tach dash added, T5, & on & on.
Huckmag is offline
post #13 of 23 (permalink) Old 02-01-2009, 12:32 PM
would a 68 289 block actually have been cast in 68 ? ......... or did they use blocks from 67 and then switch to 302
68 fastback 302 (update ! 347 8^) 4 sp
I bought a Comp Cams hydraulic roller instead of a custom ground cam because j.allen at camshaft innovations has the ABSOLUTE WORST customer relations I have ever experienced ! ................... 8^) ................... I LOVE my Comp cam !! ........ thanks j.
Buckhunter is offline
post #14 of 23 (permalink) Old 11-29-2010, 10:37 PM
QuickV8.com's Avatar
my motor says 04DR-6015-BA 6G10 12
guess its not the original? the first letter "0" by might a "D". cant tell.
ModifiedBeasts.com
2004 SVT Cobra 281 M6 · 498.5 RWHP · Stiegemeier Stage 4 Ported M112 Supercharger·Steeda 2.81 Pulley·MotoBlue Pulleys+more
Other Toys: 1967 Mustang 306 M5·1979 Firebird Formula 403 A4·1993 Camaro Z28 355 A4·1997 Mustang GT 281 M5·1987 Mustang GT 302 M5
QuickV8.com is offline
post #15 of 23 (permalink) Old 11-30-2010, 09:22 AM
Your casting code is likely actually D4DR-6015-BA
I am guessing this is for your 67 and it has a 1976 302 block.
Paul
1965 Mustang 2+2
1968 Mustang California Special
pprince is offline
