Transmission Fluid capacity - Vintage Mustang Forums
post #1 of 11 (permalink) Old 03-10-2009, 05:10 PM Thread Starter
Reverendc's Avatar
What is the automatic transmission fluid capacity for a 1965 Ford Mustang 289 V8? Mine leaks and has been sitting a while. I just put a quart in and it doesn't even register on the dip stick.
'65 Coupe
289 2v
Reverendc is offline
post #2 of 11 (permalink) Old 03-10-2009, 06:08 PM
HoosierBuddy's Avatar
Re: Transmission Fluid capacity
According to this http://www.hfmgv.org/exhibits/showroom/1965/specs.html
8 1/2 quarts for a C4.
That sounds about right. My 4R70W holds 12.
Phil
HoosierBuddy is offline
post #3 of 11 (permalink) Old 03-10-2009, 06:15 PM Thread Starter
Reverendc's Avatar
Got halfway thru the 2 quart and it started to register. Anyone have anything against AAMCO? I was thinking of having them check out the transmission leak.
'65 Coupe
289 2v
post #4 of 11 (permalink) Old 03-11-2009, 09:00 AM
dont! ask around at car shows,swap meets and find a car guy that will check it out for you first! wes
mustang656man is offline
post #5 of 11 (permalink) Old 03-11-2009, 09:07 AM
I'd suggest jacking it up, getting under it, figuring out yourself where the red stuff is dripping out, and posting back here.
It'd be about $1000 cheaper than doubleA MCO.
Phil
post #6 of 11 (permalink) Old 03-11-2009, 10:51 AM
Phil
the first thing they will want to do is 'overhaul' your trans. lots of $$$$ there. get some brake parts cleaner and get under there like suggested above. if you use the search feature here you will find where the most common leakages occur and how to properly repair them. good luck !
aka carlite65
C7ZZ-F is offline
post #7 of 11 (permalink) Old 03-17-2009, 01:34 AM Thread Starter
Reverendc's Avatar
Thanks. Will look.
'65 Coupe
289 2v
post #8 of 11 (permalink) Old 03-17-2009, 02:17 AM
If it has been sitting awhile then all the fluid in the converter has drained back into the pan which escape through the overflow tube.
First thing I would do is get under the car and have a good look at the transmission, look for area that are clean (side of case) that will give you a good indication where the leak is coming from.
It is time for you to drop the pan and drain the fluid, and also drain the converter get all the old fluid out and put some new type F fluid in. Put a new filter on and gasket (make sure the pan is flat where the bolt holes are). replace the o-ring for the filler tube if you detected any fluid leak.
Once you have re-torqued the converter drain plug and the pan is bolted back (criss-cross pattern), start adding fluid (check for any leaks), After you have added 5 quarts start the car don't rev it. Once it is running slowly shift through the gears, (at first you will not feel the car go into gear) let the car warm up and add another two quarts. Go back in the car and shift slowly through the gears this time they will engage. Slowly add more fluid remember not to over fill, every now and then look under the car for leaks.
If you take it to AAMCO they will tell you it needs a rebuild.
1966 Hardtop - Bench Seat
289 CID -4V
C4 - Automatic
Silver Frost - Black Vinyl Top
Los Angeles CA
April 06 1966
Aussie is offline
post #9 of 11 (permalink) Old 05-14-2012, 03:23 PM
Here's a good article on Mustang Monthly's site.
How To Service Ford Mustang C4 Transmissions - Mustang Monthly Magazine
durin s day is offline
post #10 of 11 (permalink) Old 05-14-2012, 03:28 PM
Hwyman's Avatar
Due to past experience (a long story), I'd rather push my car from place to place than let
Aamco touch it.
Hwyman is offline
post #11 of 11 (permalink) Old 05-16-2012, 11:45 AM
Stay away from Aamco, they quoted me $1600 for a rebuild on my AOD. Hell I could buy a new one for $1200 rated for 450hp.
milopete is offline
