loud ticking noise coming from rear end - Vintage Mustang Forums
post #1 of 31 (permalink) Old 03-26-2009, 09:08 PM Thread Starter
Send a message via AIM to ju5tin95 Send a message via Yahoo to ju5tin95
hi i have a 1966 289 c4 , and just today i hear a loud ticking noise from the rear end, any thoughts?
My art portfolio: My Online Portfolio
66' 289
ju5tin95 is offline
post #2 of 31 (permalink) Old 03-26-2009, 09:25 PM
AzPete's Avatar
Bad bearing, something loose in the brakes, nail stuck in tire, crappy music on the radio...lol
AzPete
USAF (Ret)
'07 GT Vert (The family car)
'66 Coupe (For fun)
Previously owned: Blue '66 Coupe, Red '66 Coupe, red '68 Coupe, Black '87 GT HO, Red '00 GT Vert
AzPete is offline
post #3 of 31 (permalink) Old 03-27-2009, 12:01 AM
I've heard the same noise every once in awhile as well. I don't know what it is.
65 A code fastback restoring
68 S code fastback waiting for restoration
67 C code fastback currently my driver.
coupesix is offline
post #4 of 31 (permalink) Old 03-27-2009, 08:42 AM
edboyles's Avatar
Check the universal joints......
edboyles is offline
post #5 of 31 (permalink) Old 03-27-2009, 10:21 AM
jeffdeaton's Avatar
baseball card in the spokes?
-Jeff
MCA Gold Card Judge 64.5-66
all thoughts and opinions expressed are those of my own and should not be mistaken for medical and/or legal advice.
http://www.MustangClubofTampa.com
jeffdeaton is offline
post #6 of 31 (permalink) Old 03-27-2009, 10:30 AM
68RCodeConv's Avatar
U joints.
John Bednorz
1967 Shelby GT350, dark green, 347 stroker, 5-speed, inboards, #2206
1973 Mustang Convertible, white/white, black stripes, Q-code (351C-4V), ram air.
1968 1/2 428 CJ convertible, R-code, red/deluxe red, auto, finally finished.
"If you find the car of your dreams, ignore the price guides and pay whatever you have to in order to get it."
68RCodeConv is offline
post #7 of 31 (permalink) Old 03-27-2009, 12:39 PM
Sundowners's Avatar
Re: loud ticking noise coming from rear end
Maybe a stone stuck in the tire tread?? I would get that a lot with my Jeep.
Sundowners is offline
post #8 of 31 (permalink) Old 03-27-2009, 12:42 PM
something in the hub cap?
dave
69M1SCODE is offline
post #9 of 31 (permalink) Old 03-27-2009, 03:38 PM Thread Starter
called a shop and they said to check the U joint and see if it moves left or right, seems to be very tight. So they say it might be the 3rd member. Called around and places charging me around 800 for a rebuild. Should I just go buy a whole used rear end? Some mustang yard is charging me 450 w/ 100 day guarantee. Money is tight. Whats the best way to go?
66' 289
ju5tin95 is offline
post #10 of 31 (permalink) Old 03-27-2009, 03:48 PM
franklinair's Avatar
I'd unbolt the rear u-joint and look at the 4 barrels to make sure they're not dried out.
Neil Hoppe
1968's: Best of the Best:
1968 GT/CS J Code
franklinair is offline
post #11 of 31 (permalink) Old 03-27-2009, 03:50 PM
gjz30075's Avatar
The "best way to go" is to determine, the best you can, where the noise is coming from. Does the noise come on when going slowly? If so, maybe someone can jog alongside while you coast to determine if its on either side or the middle. Try to eliminate as many variables as possible before paying someone to do the same thing.
Greg Z.
'66 GT
gjz30075 is offline
post #12 of 31 (permalink) Old 03-27-2009, 04:04 PM Thread Starter
yea i drove around and opened my car door and i was going about 5 mph and the clicking noise seems to be coming from right where the drive shaft meets the rear end. So im going to check the gear oil level first hopefully thats it if not ill have to either pull the 3rd member out but i dont want to mess it up even more because of my inexperience, should I just bring it in to the shop? I mean I am somewhat mechanically inclined I usually do all the work myself unless I need like serious shop tools.
66' 289
ju5tin95 is offline
post #13 of 31 (permalink) Old 03-27-2009, 04:35 PM
gjz30075's Avatar
Still could be U joints, which will save you from pulling the 3rd member.
But if you get to the point of pulling the 3rd member, you know that each axle needs to come first. Be sure to inspect the bearings on axles closely, as they could also be culprits here.
Greg Z.
'66 GT
gjz30075 is offline
post #14 of 31 (permalink) Old 03-27-2009, 05:15 PM Thread Starter
when I disconnect the rear U joint what exactly am i looking for? because that ticking noise sounds very sharp and clear , would it sound that clear if it were coming from the 3rd member?
oh and i checked the level on the gear oil, its right at the fill hole. Would I still need to change it out? or is it fine?
66' 289
ju5tin95 is offline
post #15 of 31 (permalink) Old 03-27-2009, 05:23 PM
jeffdeaton's Avatar
one thing i would also do is update your profile to include your location - you might have a fellow VMF'er local thats willing to give a hand
-Jeff
