How tell if correct, original engine for car? - Vintage Mustang Forums
post #1 of 16 (permalink) Old 03-30-2009, 08:56 PM Thread Starter
For my 64 1/2 289, how can I tell if it is the original engine? Thanks
scottrobey is offline
post #2 of 16 (permalink) Old 03-30-2009, 09:25 PM
Mil1ion's Avatar
Send a message via Yahoo to Mil1ion
Post all the casting numbers from the block,heads,Intake and exhaust manifolds.
Also post the last 6 digits of the VIN #
Mil1ion is offline
post #3 of 16 (permalink) Old 03-31-2009, 03:34 AM
What if i have after market exhaust and intake manifold.
meechy is offline
post #4 of 16 (permalink) Old 03-31-2009, 10:54 AM
Re: How tell if correct, original engine for car?
I recommend Bob Mannel's book on the Small Block Ford V8. It is an encyclopedic review of that engine family throughout its use by Ford and is very helpful when trying to determine exactly what you've got.
url]http://i87.photobucket.com/albums/k156/jefftepper/IMG_0027_edited-1.jpg[/url]
*67 Vintage Burgundy 390GTA has moved on to its next caretaker*
JeffTepper is offline
post #5 of 16 (permalink) Old 03-31-2009, 11:38 AM
The key word in your question is "original". For a 64 1/2 289 you *can't* tell if it is original. (Unless it is a "K" code - as they were the *only* engines stamped with even a partial VIN by Ford.)
What you can tell is if the casting dates (and the part number) are consistent with the scheduled build date (from the car's door plate). Sorry that's just the way it is for old Fords.
John Harvey
5R08A, "298"(+.060, 6,000+ rpm), T-10, FITech FI, Crane XR-i, Front Disc , Heim Jointed Struts, Spherical Bearing LCAs, Roller Perches, Arning Drop, 1" & 3/4" Anti-Sway Bars, Export & Monte Carlo, and GW Subframes.
Victory Red, Hood Scoop, Eagle 192 Wheels, Power Antenna, White Int. w/ Black trim, Right & *Left* Indicators, Tachometer, Cruise Control, Factory Style Luggage Rack, and a Glass Rear Window.
JSHarvey is offline
post #6 of 16 (permalink) Old 03-31-2009, 12:27 PM
Mil1ion's Avatar
Believe it or not there are OTHER people in this world on the net "In The Know" besides Marti or Bob Mannel.
Topic:
Yes, unless it is 1968 Mustang we cannot tell for sure if it is original but we can tell if it is the same vintage as the car.
Just post the block and heads numbers especially the 3 or 4 digit Cast Date code.
The C5AE group of numbers doesn't mean much without the date it was cast.
Mil1ion is offline
post #7 of 16 (permalink) Old 03-31-2009, 12:32 PM
CantedValve's Avatar
Send a message via AIM to CantedValve
I have a 1970 Mustang. I have 4 Cleveland blocks in addition to the one in my car. I have NEVER been able to find the last 6 of the VIN stamped on any 351C I have had. Where should I be looking?
CantedValve is offline
post #8 of 16 (permalink) Old 03-31-2009, 12:40 PM
Mil1ion's Avatar
That's because only happened in 1968
Mil1ion is offline
post #9 of 16 (permalink) Old 03-31-2009, 12:44 PM
No, all cars had a partial vin stamped on engines and transmissions starting in 1968.
Canted Valve, You are either not finding the partial vin or it is a service replacement block.
Paul
1965 Mustang 2+2
1968 Mustang California Special
pprince is offline
post #10 of 16 (permalink) Old 03-31-2009, 01:03 PM
Topic:
Hey I thought the post asked if he could tell if his car has the original engine.
IMO there's a lot of hype about numbers matching cars. In many cases we try to show that
the engine we have could be the original, the dates don't rule it out!
Years ago I had a one owner '37 Ford (I was the second). The factory number was stamped
in several locations on the frame and on the bell housing. Back then engines were frequently
swapped for factory replacements. The title would show that a new or rebuilt factory
factory engine with a new ID was installed.
Yes this wasn't Marti, it was before Marti!
My '64 1/2 vert. Ordered May '64. D code 4 speed, handling package, caspian blue, accent group, Ford blue manual top.
'68 vert. driver. Owned since Apr '78. C code AT, AC, PS, P disc B, PT lime gold, standard black interior and top. NOS RF fender and left quarter.New top and folding glass.
slim is offline
post #11 of 16 (permalink) Old 03-31-2009, 01:20 PM
actually, if you know the previous/original owner[as I do with my coupe]and trust their word/facts[as I do]you can know if your car has the original engine[and trans,and rear diff,as mine does . Another good thing to look for are the original tags that came on the carb,engine[bolted to intake],and rear diff[,bolted to the housing.]I found all three. I am somewhat lucky I suppose,but originality was important to me..Good Luck...
1966 Mustang Coupe
83,000 original miles,original engine, tranny, rear diff,
power steering,springtime yellow
originally a C-code, addded A-code intake, Autolite 4100, dual exhaust.
New leaf springs, KYB shocks, front coils,pertronix ign., thinking about dong a GT clone....
lleno is offline
post #12 of 16 (permalink) Old 03-31-2009, 01:29 PM
Lenny,
in spring of 1964 I placed a factory order for a 289 4V 4 speed vert with handling
suspension. I have the original registration for that car. Records do not exist for
Ford cars prior to '67 model year. It's my understanding that all I have is
word of mouth on my '64 1/2 vert, no way to prove it!
slim is offline
post #13 of 16 (permalink) Old 03-31-2009, 01:41 PM
ivygreen65's Avatar
Scott,
As noted previously, there really is no way to know for sure if your engine is "the" original engine for your car. However, I would suggest looking at the engine assembly date that is stamped into the machined ear on the block in front of the driver's side cylinder head. If that date precedes your car's build date by 1-10 weeks, chances are the engine is original. Components have probably been changed over the years, but you can also check their date codes to check originality.
65 Mustang Convertible 289 C-code
Rangoon Red with White w/Red Appointments Deluxe Interior
ivygreen65 is offline
post #14 of 16 (permalink) Old 03-31-2009, 01:44 PM
So where do I look? I dont claim that I have looked in the right spot nor have I inspected the entire block. I have 5 blocks... none of them have part numbers, and I pulled 3 of them from cars that I am fairly confident were original engines.
I have to believe I dont know where to look vs. it just isnt there.
post #15 of 16 (permalink) Old 03-31-2009, 02:09 PM
Sorry, but I can't help you with this.
I have seen 68 small blocks stamped on a raised pad behind the intake.
Boss 429 was on the left hand side of the block at the rear.
Paul
1965 Mustang 2+2
pprince is offline
