major leak coolant in oil pan - Vintage Mustang Forums
post #1 of 12 (permalink) Old 05-19-2009, 05:48 PM Thread Starter
I've just finished a rebuild on a 302. All done, put in the oil, and filled the radiator. Virtually all the coolant went directly in the oil pan. I have the oil pan drain plug removed and the top radiator hose. If I pour coolant in the radiator I can hear it going into the oil pan about as fast as I add it to the radiator. What could cause this. I tend to think something wrong in the oil pan or timing cover installation. Your opinions please?
1966 coupe, 306 c.i., Trick Flow heads, comp cam, air-gap manifold, Holley 570, long tube headers, Petronix billet distributor, t-5, Hurst shifter, custom ram air set up.
1995 Cobra
lowe65 is offline
post #2 of 12 (permalink) Old 05-19-2009, 05:53 PM
Banned
Freeze plug is missing
beechkid is offline
post #3 of 12 (permalink) Old 05-19-2009, 05:59 PM
68snakebite's Avatar
that would be my guess too
kind of hard to have that big of a hole in a gasket
chris
[colorrange][/color]modded 68 fastback daily driver
68snakebite is offline
post #4 of 12 (permalink) Old 05-19-2009, 07:34 PM
I won a special award
Maxum96's Avatar
Where would a freeze plug dump out at inside the pan? There aren't any inside the block and the only external ones are on the side of the block.
1970 Fastback (to be finished outside as a Boss 302 clone)
393 Windsor AFR 205 heads with 11.5:1 compression, Victor Jr. intake, solid roller cam with shaft mount roller rockers
Tremec TKO 5 Speed
Maxum96 is offline
post #5 of 12 (permalink) Old 05-19-2009, 07:47 PM
dm289's Avatar
Re: major leak coolant in oil pan
I would first check the gasket between the timing cover and the block. If memory serves me correctly there are two round ports which support the water pump. If either of these ports leaked then they would leak directly past your timing chain over the crank into the oilpan.
Another thing to consider is whether your intake manifold gaskets are correctly oriented over the water ports on either end of the heads. Once again these would leak directly into the pan through you lifter valley.
Did you use any sealer or gasket adhesive during assembly? I have found that a very light coat of RTV silicone or Gaskacinch helps a lot during gasket installation. You have to be care excessive amounts can create problems as the excess has to go somewhere
Good luck
Dan
dm289 is offline
post #6 of 12 (permalink) Old 05-20-2009, 08:21 AM
i also agree about intake manifold gasket,first one i did after a valve job in 1970 same thing happened,i hadnt cleaned the mating places of the intake and heads,second attempt solved the problem. wes
mustang656man is offline
post #7 of 12 (permalink) Old 05-20-2009, 09:21 AM
Banned
I'm not getting the freeze plug either. I'm thinking you need to take the timing cover off and check. Maybe I'm missing something but the intake shouldn't be the issue either. You're pouring directly into radiator and bottom hose is feeding into the wp. From there, it's pouring into the pan.
blue65coupe is offline
post #8 of 12 (permalink) Old 05-20-2009, 10:57 AM
oateater's Avatar
Send a message via AIM to oateater
It almost sounds like you have one heck of a crack in the bottom of your intake manifold. Was it ever dropped during the rebuild?
Wow! I dont even have a good clue where to go on this one.
65 A code coup 289 4SPD
66 A code convert 289 4SPD
38 Ford delux sedan [street rod]
oateater is offline
post #9 of 12 (permalink) Old 05-20-2009, 11:12 AM
Since you say you don't have the upper rad hose on that really only leaves the timing chain cover.
Paul
1965 Mustang 2+2
1968 Mustang California Special
pprince is offline
post #10 of 12 (permalink) Old 05-20-2009, 11:14 AM
oateater's Avatar
Forget my last post, after thinking about it I dont think its the intake manifold either if its going in as fast as you say it is. Got to have something to do in the timeing chain / water pump area.
oateater is offline
post #11 of 12 (permalink) Old 05-20-2009, 04:42 PM Thread Starter
I found the problem. I used the Fel Pro 1250 intake manifold gaskets that I have before. I put on Trick Flow heads and they don't completely cover the rear water port. I pulled the manifold and that was it. Water would pour out of about a 1/8 inch opening on each side. I replaced them with Fel Pro 1262 gaskets.
This was the first rebuild I have tried in 40 or so years. Got the car started today. Needs tuning of course. It is a 306 with a Comp Cam Xtreme Energy cam, Trick Flow heads, RPM Air-Gap with a 600 cfm carb. Also did the 4 sp to 5sp conversion. For anyone interested the drive-train shop shortened the driveshaft , added new u-joints and yoke for $128. That was much less than I thought it would be.
1995 Cobra
lowe65 is offline
post #12 of 12 (permalink) Old 05-21-2009, 07:51 AM
thanks for the update! wes
