I don’t think this has ever been done before, so I figured that I would post some pictures of the process. Some of you may find this interesting.
I am working with Tony P. of musclecarmetal (Seabrook NH.) to build a new 65 fastback body from Dynacorn reproduction parts. Tony is a Mechanical Engineer who, like most ME’s, loves cars and can’t leave well enough alone. A few years back, after restoring a Camaro with his son, Tony decided that with a solid engineering background and a thorough understanding of unibody design and construction he could build new Camaro bodies and infact, it would be easier and take less time than to trying and cut out, save, patch, etc, old rust buckets… Since then he has built a slew of 1st gen camaro bodies on his frame jig (of his design) from scratch.
Anyways, Tony and I work together at a semi-conductor equipment manufacturing company designing precision wafer handling robots (building cars is his side passion). I had been looking for a mustang for some time and getting thoroughly discouraged by $10-$15K “driver” fastbacks with rotten floors that basically need total restoration. Turns out, Tony was half interested in trying to build a mustang and my plight seemed to push him over the edge…
Anyways, here is the modified Camaro jig with the rear frame rails and complete shock tower assemblies in place according to the shop manual frame dimensions.
The shock tower assemblies are beautiful things:
If possible, I would prefer to keep this thread about the build and not have it spiral down into debates on if this is a real mustang or not and how it will be titled, blah, blah, etc…
Sounds like an interesting challenge. I've used Dynacorn pieces on my car and am very please with their quality. I believe most of the fastback sheetmetal components are available except for the inner quarter structure. Are you guys simply gonna fabricate your own?
My '65 is currently on a body cart so if your interested in any detailed photos, let me know.
If I'm asking a questsion about my car, it's a '67 Coupe, 289 2bbl, C4, P/S, manual brakes, no A/C. I'm restoring it so I can SELL IT!
302, Early 351W Heads, Windage Tray, Edelbrock 289 Performer intake, Holley 600 Carb w/1" spacer, T5 Transmission, NPD 1" Lowering Springs, 1" Mid-Eye Lowering Leaf Springs, 17" 04 Bullitts, 3.00 8" Rear, Granada Front Brakes. Still a lot of work to go and a lot of things to buy.
Seems like the A and B pillars, and roof structure are going to be a huge challenge. I'm also looking forward to see how this turns out.
BTW, Dynacorn is very close to releasing their complete 65\66 FB shell......
66 2+2 C Code Auto. 52K miles.
Something quite different coming eventually.
now sandblasted and DP40'd since this pic was taken.
a two legged hole shot, even with a munged up carb and snow tires...
I was browsing through Mustangs Unlimited catalog the other night and it looks as if one could build an entire 65-66 coupe or vert with mail order parts. The only things I didn't find were the windshield pillars and the sail panel for a coupe. That would be a dream project for me....
This excites me to some extent. I have a 68 coupe that I'm JUST getting rolling on. It's the car I drove in HS 20 years ago and it's been sitting...rusting.. since then. Since very little of the original car would remain, building one from scratch and using the part of my car that you cant buy new seems like a great idea.
The Camaro bodies your coworker was building, was that the New Bottom ones? Someone had made a jig and would fabricate the complete lower Camaro bottoms from repro parts and just weld an original roof and pillars onto the lower section.
Jason
The project vehicles:
'68 Mustang coupe, Acapulco Blue, 289, C-4, power steering
'87 Caprice Classic wagon, gold/blonde, 307, power everything (retired everyday driver)
Hopefully a '69 convert or Sportsroof (non Mach or Boss) for next Mustang project.
MCA# 66352
Trying to find my father's 1973 Mustang Grande he bought brand new. 3F04F126773 last known registration and title was in New Jersey, 1982.
Hell, the only original steel about left in my 70 is the roof, rockers, and hood. And I still feel it's a Mustang. I say your's will be a 21st century version of a 65 Mustang. Don't let the naysayers get you down. I'll be watching your build.
1970 Fastback (to be finished outside as a Boss 302 clone)
393 Windsor AFR 205 heads with 11:1 compression
Tremec TKO 5 Speed
Link to my Hub Garage and blog about my car http://www.hubgarage.com/mygarage/maxum96 My car as of March 2010
There is still a host of parts not produced. The door jambs front and rear, rear seat support for convertible, drip rail for convertible (basically everything between the rear wheel wells is all not reproduced.) No one is offering the inner rear quarter panel (piece that the rear quarter windows bolts to.
Aside from that, you need a donor car anyway to come up with the rest of the stuff that isn't reproduced. I still haven't seen a top frame, headliner bows, etc. The list is endless.
As for dynacorn. They are good because of what we are used to. Reproduction parts have just plain sucked in the past. Dynacorn is just marginal, but I have had my issues with some pieces simply not being the same size, length or otherwise just plain wrong.
I was about to buy one of their complete floors and start the work of putting a car back together on it. Complete as in the 2200 piece that is everything from the firewall back. I am glad I didn't. At a show, I saw one all painted pretty to display some suspension parts. The welds were the same quality you might expect from a kindergartner. (hmmm...seems to make sense given the country of origin) The panels are spot welded together like original, but for some reason, they pay some kid to go in there and start slinging slag wherever he thinks it needs to be stronger. (my opinion) The unit I saw had welds all over it, nearly between every panel. It was so disgusting.
Moral of the story...magazine guys love the new Dynacorn stuff. It must be really cool to see it before anyone else and give an opinion about it. Oh yeah, and Dynacorn is a huge advertiser. So they just write about how wonderful it is and how much stronger it is that the original Ford stuff and it's so wonderful....What you get is much, much different that you expect.
65 'T' Coupe 250 5 speed ~ Preparing for a 250 conversion
65 'A' Convertible 4 speed Factory GT
66 F100 460 Auto ~ Grandpa's truck being restored at http://bluestang65.blogspot.com
Probably, he offers complete floor assemblies or builds what ever someone wants...
As for the internal structure, yes, a donor will be used...
Looking good so far, I'll be following this thread.
Now are you gonna be adding any non-factory chassis rein-enforcements and such?
We are adding 67/68 front torque boxes and the Dynacorn 1 piece seat pan and I am considering adding the convertible under floor reinforcements. I will also probably do some of the boss boxing of the shock towers and fab a beefed up crossmember and of course a monte carlo bar and export brace. Against the popular vote, I am not sold on subframe connectors yet… I want to do side exhaust and subframe connectors make that difficult, plus I have yet to see any real data on their effectivness. You would think that with the number of high dollar companies selling them, someone would have some data to show their effect on chassis torsional stiffness. The best chassis stiffening approach I have seen was done by Julien's:
I have talked to Bob there, great guy, he has analyzed mustang unibodies and has performed actual torsional stiffness testing, I hope to inproporate some of their ideas.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
