» Network Links
»Super Springs
Old 11-03-2009, 01:51 PM   #16 (permalink)
whisperer's Avatar
At least pulling the heads is an easy job on a SBF vintage Mustang, especially if they have been off in the last decade......
Did you get to it on Sunday? If so then what did you find?
**Never drive faster then your guardian angel can fly**
whisperer is offline   Reply With Quote
Old 11-03-2009, 02:01 PM   #17 (permalink)
buening's Avatar
I too recommend a leakdown test if it is available. This would narrow it down to a cylinder or two, so that you know where to look for cracking or blown gasket
70 Mach 1 - 351w/FMX
70 SportsRoof - 302/C4
05 FX4 F150 - Fully loaded baby!
06 BMW 530xi
buening is offline   Reply With Quote
Old 11-03-2009, 07:42 PM   #18 (permalink)
Lemondrop's Avatar
Send a message via AIM to Lemondrop
Default gasket
The trouble with leakdown is unless the crack is huge, it may not show up unless the engine is at operating temperature. If you do it cold, the crack may be "shut" with carbon and or just the metal itself. Many cracks don't open and start leaking unless the metal is hot. I'd yank the heads if compression in the cooling has been confirmed and then either scrap the heads in favor of aftermarket heads or plan on having a teardown with full magnaflux (mag particle) testing to located possible cracks. We had a tank back when I was at Caterpillar that was heated up to 180ish degrees that cylinder heads were dipped into for testing. The heads would have deck plates bolted to them to block off coolant passages and any other coolant passages were capped off with a block off plate. One plate had a QD for compressed air that would be pumped into the casting during it's soaking in the hot water tank. If the headgasket has simply blown, the head surface will need to be checked (along with the block) for a true straight sealing surface. If both are flat and no cracks present, you might get away with new gaskets. Id so, you may consider swapping to head studs instead of bolts for better clamping force.
Cardomain page for the Rustang
Lemondrop is offline   Reply With Quote
