How to cap heater hose output on water pump? - Vintage Mustang Forums
post #1 of 14 (permalink) Old 11-01-2009, 09:41 PM Thread Starter
Tims65's Avatar
I eliminated my heater, so I need to need to cap the heater hose output on the water pump. I am using both of the intake manifold water ports, one for the temperature gauge sending unit and one for the computer temperature sending unit, so I can't just reroute it into the intake.
So what is a good way to cap the heater hose output port?
'65 2+2
347 - Holley DP - 471 fwhp
JBA shorty's, 2.5" tubes, Dr Gas X-pipe
T-5 world class 5 speed, w/ .80 OD
9" with 3.70's & T-loc
4 wheel Wilwood disc brakes
17" CL-205's, 225/45 & 255/40
TCP/Global West suspension
OpenTracker roller spring perches
subframe connectors, Panhard bar
TCP manual rack & pinion
Power door/window locks w/ keyless entry
Driven, not pampered
Tims65 is offline
post #2 of 14 (permalink) Old 11-01-2009, 10:19 PM
frdnut's Avatar
It looks like you are already running the short rubber cap?..The next best option is to remove the short peice of metal tubing and tap the water pump and install a plug...
68 J code sprint, 408W
11.47@123.35mph in street trim.
frdnut is offline
post #3 of 14 (permalink) Old 11-01-2009, 10:47 PM
brianstrange's Avatar
Maybe one of these will help? Breeze Automotive Factory Five Racing
Then run a bypass hose
Semi Pro Touring 67 Mustang Convertible * Mild 5.0 EFI * AOD * 68 8" rear end * Aeroform R&P * Open tracker roller perches * Arning Drop * 560 LB 1" lowering front springs * 1.25 front sway bar * Koni front, Grab a track rear shocks * 15x7 Shelby 10 spoke 4.25" BS and 225-60-15 http://www.facebook.com/album.php?ai...6&l=9f637753c1
brianstrange is offline
post #4 of 14 (permalink) Old 11-01-2009, 10:47 PM
+1.
65 'T' Coupe 250 5 speed ~ Currently under the knife
66 F100 460 Auto ~ Grandpa's trucks
View my resto blog mustangsurgery.blogspot.com
sixteenpushrods is offline
post #5 of 14 (permalink) Old 11-01-2009, 11:28 PM
SAC69's Avatar
I've used a cap for several years w/o any problems, I do replace it once a year though. I plan to drill & plug the water pump when I replace it.
Tom
69 Sportsroof 351W
forsan et haec olim meminisse iuvabit
a.m.d.g.
Go Navy!
SAC69 is offline
post #6 of 14 (permalink) Old 11-02-2009, 07:53 AM Thread Starter
Tims65's Avatar
I had the rubber cap on, but it didn't last long. What's the best way to pull the hose nipple out of the water pump? - any tricks?
Also, any suggestions on how to tap the bypass with the waterpump installed?
That piece looks interesting, but won't it taint my temperature readings? If this piece installs in the intake manifold and then the temp sending unit installs on top, then the sending unit will be out of the main flow and just read the water that is sent through the bypass. Will this give false readings until the car is at full operating temperature?
Thanks for the replys everyone.
Tim
Tims65 is offline
post #7 of 14 (permalink) Old 11-02-2009, 08:02 AM
A 9/16 freeze plug will fit in the hole if you remove the nipple
67 coupe White/Parchment
331 T-5 and 3:80 Gears
Edelbrock F4B with 650 Quick Fuel
Tri Y with 2 1/4" H pipe Flowmaster 40s
QA1 Coil overs
65 Vert White/Red/White
289 D code 4 speed
Born April 22 1964
65 Ranchero Red
170 3 Speed
In progress
Haywired is offline
post #8 of 14 (permalink) Old 11-02-2009, 08:05 PM Thread Starter
Tims65's Avatar
Nice! That's the way I'll go, I don't have to remove the water pump to tap the threads.
Any tips on removing the hose nipple? Do I just grap it with some plyers and twist and pull at it?
Also, exactly how do you install a freeze plug? I've never done it. Do I just tap it in with a mallet until flush or do I need any specific tools? Does the freeze plug material matter? The water pump is aluminum.
Thanks, I love this place!
Tim
'65 2+2
Tims65 is offline
post #9 of 14 (permalink) Old 11-02-2009, 08:22 PM
Fast68back's Avatar
Put a socket inside the freeze plug and tap that
-Rick
IF YOU DON'T STAND BEHIND OUR TROOPS,
PLEASE, FEEL FREE TO STAND IN FRONT OF THEM
Fast68back is offline
post #10 of 14 (permalink) Old 11-03-2009, 08:13 PM
slow-poke's Avatar
If you plug both ports, make sure you drill a small hole in your thermostat. You need to have some coolant flowing when the thermostat is closed, or you can/will experience "hot spots" while the thermostat is closed.
408 - 5 spd. 10.x through the mufflers
slow-poke is offline
post #11 of 14 (permalink) Old 11-05-2009, 01:46 AM
Mine is kind of dodgy but has worked ok for a few years.
Short length of heater hose with an appropriate sized bolt hose clamped in place. Doesnt leak at all and does the job.
C0V3R is offline
post #12 of 14 (permalink) Old 11-07-2009, 02:21 PM Thread Starter
Tims65's Avatar
How do I remove the output nipple from the water pump!? Anyone??
I cannot get it to budge. Any tips appreciated.
Thanks,
Tim
'65 2+2
Tims65 is offline
post #13 of 14 (permalink) Old 11-08-2009, 09:24 PM Thread Starter
Tims65's Avatar
Well, I finally got the heater hose output on the water pump plugged and per usual, not without the multiple trials and tribulations.
Originally, I capped the heater hose output with a rubber cap, held on by a hose clamp. This method didn't even get me out of the driveway.
Next up, I tried a rubber expansion plug. This gave way 15 miles out on my first shakeout drive.
So, then the post about using a freeze plug. But, I thought I could make it one step easier by placing the freeze plug in the output nipple, instead of pulling the nipple and placing it directly in the water pump body. I went to the auto parts store and left with a handfull of various sized freeze plugs. I tested them all, until I found the perfect fit, then started tapping it in using the socket method. Well...I didn't realize that the nipple had a lip on it. I started tapping the freeze plug into place. It was the perfect snug fit, until, all of the sudden the freeze plug and my socket disappeared inside of the water pump. I was able to retreive the socket with my magnetic wand, but I couldn't get the freeze plug back out....thus the panic about "how to remove the nipple on a water pump".
So, I pounded a screw drive through the output nipple and finally wrangled it out. A 3/4 freeze plug fit snugly into place.
Thanks,
Tim
'65 2+2
Tims65 is offline
post #14 of 14 (permalink) Old 11-08-2009, 11:07 PM
roadracer's Avatar
Tim,
A 1/2" NPT tap will fit the stock hole perfectly. Load it up with grease to catch the cuttings and tap that hole.
Then put a 1/2 NPT plug in there.
If you want to ever go back to heater hose they make a 1/2"NPT threaded hose barb you can put in there to attach a hose to.
"If you're under control you're not going fast enough"
Parnelli Jones
Visit Roadracers Corner
roadracer is offline
