» Network Links
»Super Springs
Old 11-17-2009, 10:26 PM   #16 (permalink)
Just some guy
GypsyR's Avatar
I've grown very fond of the new teflon rear seals. I've used them in a couple of applications to cure leaking OEM type seals. Only for one-piece type rear mains though. Doesn't sound like your mechanic has looked at these yet-FelPro #FEL2942RS.
Dunno about a rear seal "shedding" rubber to cause the oil to turn black. Sounds pretty far-fetched to me. Seems like most oil drips I've ever seen from the bellhousing area look black when found on a street-driven automobile. Doesn't matter where exactly it leaks from or how new the oil is, drips back there just look nasty. I don't claim to know exactly why that might be.
GypsyR is offline   Reply With Quote
Old 11-18-2009, 12:22 AM   #17 (permalink)
frdnut's Avatar
Originally Posted by GypsyR View Post
Dunno about a rear seal "shedding" rubber to cause the oil to turn black. Sounds pretty far-fetched to me. .
I agree...
68 J code sprint, 408W with vic jr top end, Pro Systems 950HP Holley,Camshaft Innovations custom solid roller ,Hooker 6208s,Toploader,4:11 Detroit locker
frdnut is offline   Reply With Quote
Old 11-18-2009, 02:56 AM   #18 (permalink)
Send a message via ICQ to camachinist Send a message via AIM to camachinist Send a message via Yahoo to camachinist
I used moly lube in a few places.
If you've got a leaking gallery/cam plug/rear seal, the molybdenum disulfide which collects at termination points can make the oil appear black.
Visit my VMF lingo page
Visit the Ford engine torque specs page
Visit my MySpace Blog
camachinist is offline   Reply With Quote
Old 11-18-2009, 09:03 AM   #19 (permalink)
Send a message via AIM to crickifur Send a message via Yahoo to crickifur
well that sounds like a smart comment, not exactly sure what it is but it sounds complicated enough to make sense hahaha
1967 Coupe PROJECT
Possibly lookin for another....
crickifur is offline   Reply With Quote
Old 11-18-2009, 10:39 AM   #20 (permalink)
+2 on this thinking. I've got a pretty good leak in the rear of mine after several thousand miles from new; probably the rear main for some reason but the oil coming out is crystal clear.
Perhaps you're running really rich?
Greg Z.
'66 GT
gjz30075 is offline   Reply With Quote
Old 11-18-2009, 09:13 PM   #21 (permalink)
Originally Posted by Maxum96 View Post
It's a brand new engine. The only part that was rebuilt and reused was the block. All top of the line high dollar parts inside and out. The oil is being blackened as it leaks out. I'm hoping the discoloring of the oil is a tip as to the source of the leak.
Taking a shot at your leak,
Possiable that the builder got some assy lube on the rear main.
I have seen roped (and 1 rubber) rear mains leak from it.
Seems the rope ones are prone to glazing from the assy lube and start leaking very quickly.
The discolored oil was the clue to looking there first.
If it's already broken....I can't hurt it.
pabear89 is offline   Reply With Quote
Old 11-20-2009, 08:40 PM   #22 (permalink)
That's an effing manufacturer defect. Those have a metal support molded into them. Everything looks perfect otherwise. Was that a Fel-Pro seal? Well, I guess the builder got a wake-up call to start checking lip seals in detail. I work with them for a living and check each one with my finger and a light since they're usually holding a couple thousand psi of hydraulic pressure.
Old 11-20-2009, 08:47 PM   #23 (permalink)
Maxum96's Avatar
I guess I was a little slow and you posted before I pulled my previous message. I started a new thread because I couldn't update the title. The nick looks like it might have gotten cut with a razor blade.
1970 Fastback (to be finished outside as a Boss 302 clone)
393 Windsor AFR 205 heads with 11:1 compression
Tremec TKO 5 Speed
Link to my Hub Garage and blog about my car http://www.hubgarage.com/mygarage/maxum96
My car as of December 2009
Maxum96 is online now   Reply With Quote
