» Network Links
»Super Springs
Old 11-20-2009, 08:39 PM   #1 (permalink)
Maxum96's Avatar
Default Engine gurus, oil leak question. UPDATED-PROBLEM SOLVED!
Found the problem! It turned out there was a nick in the upper half of the rear main seal. Don't have a clue how it got there. The engine builder was surprised to hear it. Who knows when it happened. Could of happened when it was made and packaged. Could have happened when it was taken out of the package. You had to look closely to see the nick. But it was all the way through the lip of the seal. The oil was being turned black when the oil dripped between the heat shield of the scattershield and the block. Two pieces of metal rubbing together with oil between them will make the oil black. So kind of pain to pull everything apart, but at least I won't have a motor that leaks oil now.
Thanks for all the tips and suggestions.
Full size the picture to see the nick.
1970 Fastback (to be finished outside as a Boss 302 clone)
393 Windsor AFR 205 heads with 11:1 compression
Tremec TKO 5 Speed
Link to my Hub Garage and blog about my car http://www.hubgarage.com/mygarage/maxum96
My car as of December 2009
Maxum96 is offline   Reply With Quote
Old 11-20-2009, 08:56 PM   #2 (permalink)
Barn Finds or Bust
DRAGPAK428's Avatar
Glad to hear it, that kind of problem will have you second guessing everything.
I had a similiar mind bender this week, intermittent stumble on a 67 fastback 289 4spd, it would sometimes do it when it was cold,hot when accelerating and when decelerating.I tracked it down to a bad coil, this was after questioning everything over and over, turns out the new coil I got was bad too so I spent a good part of the day rechecking everything until I figured out Napa gave me a new bad coil!
Congrats on your fix
DRAGPAK428 is offline   Reply With Quote
Old 11-20-2009, 09:21 PM   #3 (permalink)
Wow such a small nick, did you have to pull the engine to replace it?
1966 Hardtop - Bench Seat
289 CID -4V
C4 - Automatic
Silver Frost - Black Vinyl Top
Los Angeles CA
April 06 1966
Aussie is offline   Reply With Quote
Old 11-20-2009, 09:50 PM   #4 (permalink)
6t9mach1's Avatar
Glad you found it but too bad it was the rear main seal. Always a pain in the butt!
~Ryan~
1969 Mach 1: 4.11 Detroit Locker, 31-spline axles, AODE swap coming this winter, new 500hp solid roller 357w engine build under way
http://www.cardomain.com/ride/2554478
6t9mach1 is offline   Reply With Quote
Old 11-20-2009, 09:55 PM   #5 (permalink)
Maxum96's Avatar
No. Drop the engine crossmember, unobolt the steering idler arm and the pan drops down. Then I had to unbolt all my main caps as I use a main stud girdle. Then pull of the cap. The seal is a 2 piece. Grabbed the top piece above the crank with a pair of pliers and pulled it out. Just reversed everything. Not as bad as you might think to do.
Tremec TKO 5 Speed
Old 11-20-2009, 10:47 PM   #6 (permalink)
frdnut's Avatar
Hopefully that was all it was..Rear main leaks can be a nightmare.
68 J code sprint, 408W with vic jr top end, Pro Systems 950HP Holley,Camshaft Innovations custom solid roller ,Hooker 6208s,Toploader,4:11 Detroit locker
frdnut is offline   Reply With Quote
Old 11-20-2009, 11:08 PM   #7 (permalink)
Originally Posted by Maxum96 View Post
I use a main stud girdle......Not as bad as you might think to do.
lol..... HEY NOW! ;-)
67 Mustang Convertible * Mild 5.0 EFI * AOD Transmission * 68 8" rear end * Aeroform R&P * Open tracker roller perches * Arning Drop * 560 LB 1" lowering front springs.
brianstrange is offline   Reply With Quote
