» Network Links
»Super Springs
Vintage-Mustang.com is the premier vintage Ford Mustang forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 02-27-2010, 03:09 AM   #1 (permalink)
Default read everything how do i bypass pink resistor wire and what do i do with it
read everything how do i bypass pink resistor wire and what do i do with it when i bypass it tape it up,wrap it up.im hooking up pertronix ignitor and flamethrower coil the coil needs 12v i need to bypass the pink wire and after i do what do i do with it.can you give me a step by step please.
raiderdave007 is offline   Reply With Quote
Old 02-27-2010, 06:27 AM   #2 (permalink)
Just put a Scotchlock connector on it near the firewall under the dash. Then slide a female 0.76 bullet connector on the switch end plug. Make a wire that runs from the Scotchlock to the ignition switch, with a 0.76 male plug, and you are done.
Scotchlock:
http://www.midterminc.com/media/5602.gif
Amateur restorer. (Well, once in a while I have been paid for it)
22GT is offline   Reply With Quote
Old 03-12-2010, 10:30 PM   #3 (permalink)
Default Did it work
RaiderDave007,
Did you get it to work?
22GT,
Looking to do this tomorrow. I have the connectors. How do I know where to connect the Scotchlock connector to-when would I be passed the resistor? Would I be able to see the resistor, then go to the switch side of it?
I've looked under the steering wheel. I see the Red/green wire. My car doesn't have the pink one. Just also replaced the underhood gauge wires and the new wire is red with green stripe.
thanks,
Bob
1971 Mach 1
sadlerb_98 is offline   Reply With Quote
Old 03-12-2010, 11:26 PM   #4 (permalink)
most of the times the pertronix ignitor and flamethrower coils work fine with the resistor wire in place. I'd try that first.
Z. Ray
'66 GT-350
original drivetrain, sheet-metal, interior, & paint
zray is offline   Reply With Quote
Old 03-13-2010, 12:24 AM   #5 (permalink)
franklinair's Avatar
I didn't do the bypass exercise either. Everything works fine.
Neil Hoppe
1968's: Best of the Best:
1968 GT/CS J Code
1968 Conv. J Code
franklinair is offline   Reply With Quote
Old 03-13-2010, 08:03 AM   #6 (permalink)
Ratt-N-Roll
66sprint200's Avatar
No bypass & working great for me also on 2 Mustangs. Dean
'66 GT FB
66sprint200 is offline   Reply With Quote
Old 03-13-2010, 09:13 AM   #7 (permalink)
Good replies. Thanks. I have the Pertronix II and Flamethrower II coil. Wonder if that makes a difference.
1971 Mach 1
Old 03-13-2010, 10:39 AM   #8 (permalink)
2 more pertronix using the resistor wire without any problems.
Doug
classicdoug is offline   Reply With Quote
Old 03-13-2010, 10:41 AM   #9 (permalink)
I also have the Pertronix II & Flamethrower II. No bypass. No problem
Neil Hoppe
1968 GT/CS J Code
1968 Conv. J Code
Old 03-13-2010, 12:03 PM   #10 (permalink)
MarkStang's Avatar
I have the Paytronix II and all is good here with pinky.
-Mark
Our Children , Inspire The Future
Love Your Children
My Window Trim Removal Videohttp://www.youtube.com/user/markstan.../4/bRJf5Ow4YbU
MarkStang is offline   Reply With Quote
Old 03-13-2010, 02:14 PM   #11 (permalink)
Sorry for butting in! If the subject Mustang (my 68 in this case) has factory tach anybody know if bypassing the resistor wire would be bad for the tach?
slim is online now   Reply With Quote
Old 03-13-2010, 05:16 PM   #12 (permalink)
IIRC, If you bypass the res wire the tach won't work.
If it's already broken....I can't hurt it.
pabear89 is offline   Reply With Quote
Old 03-13-2010, 09:48 PM   #13 (permalink)
in a '66 the res (pink) wire is after the tach, don't know about the '68.
Z.
'66 GT-350
Old 03-14-2010, 04:58 AM   #14 (permalink)
After seeing this, I think this is the proper way to wire a Pertronix.
Erwin, The Netherlands,
66 Red Convertible,289ci 2V /C4/PDB/PS/PT. Visit my HOMEPAGE for lots of pictures.
66candy is offline   Reply With Quote
Old 03-14-2010, 10:09 AM   #15 (permalink)
6V Coil
