Custom Motor Mount Build - Page 11 - Vintage Mustang Forums
Old 09-22-2012, 06:38 PM   #151 (permalink)
dobrostang's Avatar
Originally Posted by Le Singe Psycho View Post
Everybody seems to be moving their engine down and back. Do you suppose there is room enough to move the engine forward so as to be able to accomodate a 9" rearend swap or T5 swap? Normally these require shortening of the driveshaft but could the engine be scooted forward to avoid driveshaft work? Either way, I'd love to have the set of pdf and cad files @ welche@msn.com.
Thanks,
JACK
Its only $100 to have your shaft shortened, (I know that is not a manly thought process) Its not a big deal and IMHO, its better to get the shifter where you want it, at least in my case because I didn't want to cut up my interior. Most people who don't move the motor have to notch the trans hump for the shifter on a T5. From there it can take an ape to reach the shifter. I wanted the shifter in the sweet spot - then I cut off the old Toploader Hurst shift handle and drilled it to bolt onto my new trans so for all intents and purposes it looks like my old toploader - even with the vintage knob with the wrong shift pattern. I can even use a stock shift boot so you would never know its a Tremec.
dobrostang is offline   Reply With Quote
Old 09-23-2012, 02:50 PM   #152 (permalink)
fej
Please add me to the requester list and send when you can. Thanks Buening
fej66@yahoo.com
fej is offline   Reply With Quote
Old 11-26-2012, 04:46 PM   #153 (permalink)
Default Motor Mount Drawings
Are these drawins still available?
RogStang
rmoseby@gmail.com is offline   Reply With Quote
Old 11-26-2012, 05:30 PM   #154 (permalink)
buening's Avatar
They sure are! Do you want them sent to the email you use as a username?
70 Mach 1 - 351w/T-56
70 SportsRoof - 302/C4
05 F150 FX4
06 BMW 530xi
T56 Conversion Thread
Custom Motor Mount Build Thread
buening is offline   Reply With Quote
Old 01-02-2013, 01:01 AM   #155 (permalink)
Could I get a copy of your awesome motor mounts? This is something I'm definitely going to need in the future. rodimal86@gmail.com
Thanks!
1969 Ford Mustang Coupe; 351w (5.8L) carb engine; Champion 4 row aluminum radiator; Edelbrock Performer RPM Intake Manifold; Edelbrock 750 CFM Carb; Crager Wheels; 215/60-15 front tires, 255/60-15 rear tires; Doug Tri-Y Headers; Custom Dual Side Exit Exhaust w/Xpipe; MSD 6AL; Electric Fuel Pump; March Performance U/D Pulley Set; Curved Monte Carlo Bar.
My Life
Tarmac_69_Mustang is offline   Reply With Quote
Old 01-02-2013, 07:41 AM   #156 (permalink)
Send a message via AIM to robert_t_wallace Send a message via MSN to robert_t_wallace Send a message via Yahoo to robert_t_wallace
Originally Posted by buening View Post
Thanks Matt! I've probably sent out over 100 of these emails, so a direct link would help a bunch!
I have a website called The Vintage Car (Welcome to The Vintage Car - The Hot Rod, RatRod, Muscle Car, Street Rod & Classic Car Information Portal) that I don't mind putting your drawings up on... It fits the them I have for DIY...
If interested, please let me know and I will create a category for them.. The Forums are at:
Forum Index - The Vintage Car - The Vintage Car
Todd Wallace
Check Out My Website:
The Vintage Car
robert_t_wallace is offline   Reply With Quote
Old 01-02-2013, 11:01 AM   #157 (permalink)
buening's Avatar
Thanks!
Files sent
That works for me! Let me know if you need the files again.
05 F150 FX4
06 BMW 530xi
Old 01-02-2013, 11:26 AM   #158 (permalink)
Files sent
go ahead and send me (again) what you want posted to todd@thevintagecar.com
Todd Wallace
The Vintage Car
Old 01-02-2013, 07:58 PM   #159 (permalink)
Just added them if anyone needs to reference them...
Here are the drawings:
Drawings - The Vintage Car - The Vintage Car
Here is the forum group that has the posts with the pictures and drawings:
Motor Mount plans (Topic list) - The Vintage Car - The Vintage Car
Let me know if I need to change or add anything.. Feel free to link to them...
Todd Wallace
The Vintage Car
Old 01-03-2013, 10:40 AM   #160 (permalink)
buening's Avatar
Thanks!
05 F150 FX4
06 BMW 530xi
