1965 gas tank leaking - Vintage Mustang Forums
post #1 of 18 (permalink) Old 06-26-2010, 02:02 PM Thread Starter
Hey guys my 1965 gas tank is leaking at the petcock or where the fuel lines hook up. i had a fuel pump go out and i had to pull the electric pump off just to get home. so i hooked up the lines back to the tank bypassing the fuel pump. well i had to turn the hose port on the gas tank and now its leaking, is this fitting welded into the tank and it just rusted or is there a seal on that tank where the fitting goes in.
thanks
Matt
1965 Mustang Deluxe aka Pony car. daily driver, 306 Cobra ,Edelbrock Performer RPM heads, Edelbrock 1406 carb modified, Full electric MSD ignition and distributor. custom long tub headers and flowmaster exhaust. My stang http://forums.vintage-mustang.com/me...s-my-pony.html
mhart032 is offline
post #2 of 18 (permalink) Old 06-26-2010, 02:15 PM
22GT's Avatar
thanks
Matt
The tube is permanently attached. If the tube is leaking, the sender is trashed.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #3 of 18 (permalink) Old 06-26-2010, 02:16 PM
bbpschools's Avatar
did you twist it tight enough. and if all else fails weld it
bbpschools is offline
post #4 of 18 (permalink) Old 06-26-2010, 02:20 PM
If you have a stock tank (donno what was done/modified for electric pump) the fuel outlet is on sender. The sender is removeable and has a seal/gasket/O ring to the tank.
My '64 1/2 vert. Ordered May '64. D code 4 speed, handling package, caspian blue, accent group, Ford blue manual top.
'68 vert. driver. Owned since Apr '78. C code AT, AC, PS, P disc B, PT lime gold, standard black interior and top. NOS RF fender and left quarter.New top and folding glass.
slim is online now
post #5 of 18 (permalink) Old 06-26-2010, 02:22 PM
OMG! Don't weld by/on the gas tank!
slim is online now
post #6 of 18 (permalink) Old 06-26-2010, 02:38 PM
Like 22GT said. If it's leaking where the fuel line/tube comes out (that's the sender) the sender is likely shot.
slim is online now
post #7 of 18 (permalink) Old 06-26-2010, 02:44 PM
theres a lock ring that holds sender to tank-remove by tapping ring to remove.then u can braze or solder the tube to the sender again or replace sending unit. wes
mustang656man is offline
post #8 of 18 (permalink) Old 06-26-2010, 05:21 PM Thread Starter
Guys, its not the sending unit. its the elbow that is attached to the tank. its leaking from around the 2.5 inch hole in the tank. the sending unit is working fine.
mhart032 is offline
post #9 of 18 (permalink) Old 06-26-2010, 05:25 PM
22GT's Avatar
No such thing, unless home-made.
Then you need the square o-ring seal.
22GT is offline
post #10 of 18 (permalink) Old 06-26-2010, 06:07 PM
hahahaha, my exact thoughts.
sanchtech is offline
post #11 of 18 (permalink) Old 06-26-2010, 06:13 PM
The sending unit can be working fine and still leak! Two places it can be leaking. The O ring at the 2" hole, or where the sending connection comes through the middle. Neither affects the gauge reading!
slim is online now
post #12 of 18 (permalink) Old 06-26-2010, 06:31 PM Thread Starter
ok i see whats your saying. i think the o-ring mite be bad. or when i turned the elbow i may have just loosened the connection. but if i correct this can be replaced without replacing the fuel cell correct?
mhart032 is offline
post #13 of 18 (permalink) Old 06-26-2010, 06:43 PM
A while back I said is it stock fuel tank? No reply! If you don't say what you have how can we help?
slim is online now
post #14 of 18 (permalink) Old 06-27-2010, 05:30 PM Thread Starter
Sorry its the stock fuel tank.
Matt
mhart032 is offline
post #15 of 18 (permalink) Old 05-11-2015, 08:24 PM
I'm having the same issue on my 65, and I've a brand new tank. I was hoping there'd be a YouTube video on making sure that whole assembly is correctly fitted.
MattJr007 is offline
