200 6 cyl want more horse power... - Vintage Mustang Forums
post #1 of 7 (permalink) Old 07-25-2010, 01:24 AM Thread Starter
I want to keep the original 6 in my car and I know they are rated at about 120 hp. I was wondering if i could get it to hit 200 hp with modifications, nothing crazy maybe header, exhaust stuff like that....
klmustang67 is offline
post #2 of 7 (permalink) Old 07-25-2010, 01:45 AM
Wiz998's Avatar
When I had my 6 I had headers and the dui dizzy and I felt like I was going to crap my pants. You should check out the ford6forum for more info.
Fabion
1967 coupe I6,Dui dizzy,front disc,first car. 08/17/07-06/27/09 =(
1970 Fastback 5.0 efi hydr clutch.to be my DD. 8/9/10-11/26/13 =(
1969 Fastback project hardfind 12/14/13
08 focus 2dr coupe dd
If you can afford a new car you can afford a classic car.
Wiz998 is offline
post #3 of 7 (permalink) Old 07-25-2010, 08:42 AM
John_Del's Avatar
You certainly can get them to move, but it cost more per hp for a six than it does for an eight.
The whole engine is a bottleneck, and improving just the exhaust won't fix the flow. You need to address the carb, intake, heads, and exhaust to get the air and fuel in , combusted, and out as efficiently as you can.
If it's not a money issue, a properly built six can be a lot of fun and a rare exhibit. I know the Aussies make wonderful stuff with which to build a proper six.
Ford Six Performance Home/Index
Do NOT send me a private message, email me directly:delstv@aol.com
http://i689.photobucket.com/albums/v...mustangftp.jpg
now sandblasted and DP40'd since this pic was taken.
http://i689.photobucket.com/albums/v...ngdriveway.jpg
a two legged hole shot, even with a munged up carb and snow tires...
John_Del is offline
post #4 of 7 (permalink) Old 07-25-2010, 08:48 AM
lunarweasel's Avatar
Will cost a couple grand to get to 200 HP. (head, carb, headers, etc). I think if you go to 200 HP on a 6 you would have to change out the rear end to a V8 one, maybe someone else can chime in on that.
I love 6's, and I think the dual carb adapter, the headers, maybe a different rear end gear, and maybe some sort of four speed (or 5 speed) might be a way to wake it up for less.
5R07C, 4spd Toploader, Black Std Interior, Originally Ivy Green, Edelbrock 500cfm-4V on Perf 289 Intake,
Hurst Super Shifter, Baer SS4 Disc Brakes (4-piston, Aluminum, USA Made),
New Front Susp. w/Shelby Drop, New Steering, Drake Export Brace / 1" Sway Bar / Monte Carlo Bar, Mallory Unilite Distributor
lunarweasel is offline
post #5 of 7 (permalink) Old 07-25-2010, 08:52 AM
Explorer's Avatar
For 200hp you will have to get a "little" crazy. Classic Inlines Performance Parts - Home Here you will find engine builds in stages and parts needed. Check the Dyno results for actual gains when adding parts. Depending on condition of your engine, a 250ci swap will give you a 25% increase.
66 Coupe 200I6 (Back under restoration)
Explorer is offline
post #6 of 7 (permalink) Old 07-25-2010, 09:58 AM
NEFaurora's Avatar
Try also Ford Six Performance Home/Index for 6cyl performance parts.
Tony K.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual
MCA#70001
NEFaurora is offline
post #7 of 7 (permalink) Old 07-25-2010, 12:31 PM
TheDude's Avatar
My 200ci has a 2bbl carb, header with dual exhaust and electronic ignition. It has a stock C4 with a stock rear. I have been planning my restoration and it includes keeping the six but with a few more upgrades. I think 120hp was a generous rating from Ford many years ago. Realistically, I think they are much lower (not sure what the numbers are). I don't want to go crazy with the engine rebuild because if you are really looking for power, just do the V8 swap. You can easily drop thousands into the I6 engine just to get it up to stock V8 HP. I want something that will be fun to drive on the street. I have no desire to race with it.
Here's a link to some clips of my exhaust.
Justin Nast Acoustic
1965 Six Cylinder Coupe
1953 Buick Super
Inline Six Exhaust Clips
TheDude is offline
