1970 Mach 1 Engine Compartment Wiring - Vintage Mustang Forums
post #1 of 8 (permalink) Old 10-03-2010, 04:45 PM Thread Starter
Hi I am looking for photos and feed back on engine compartment wiring. I am in the process of rewiring the car, I have the wiring all figured out as far as point a to b but I am looking for help on how the wiring is routed. Clip types and locations best way to wrap the wires etc..Also trying to fing where I can find some factory style connectors, push on type wire connectors, for the coil, temperature and oil sensors etc..and the two wire male/female plugs.
Any help would be greatly appreciated. Its not a concours restoration but I want it to look neat and correct. The car has a 351 C engine, automatic, Mach 1, no a/c, no tach.
Ken
Kenzo is offline
post #2 of 8 (permalink) Old 10-03-2010, 05:16 PM
22GT's Avatar
Repair plugs for 1, 2, 3, and 4 connector are available. Also, all the plastic clips are available, as far as I know.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is online now
post #3 of 8 (permalink) Old 10-03-2010, 08:26 PM
Routing is easy, the Electrical Assembly Manual shows where everything is routed, and which clips are where, as well as provides the wiring diagrams. Well worth the cost.
The clips and retainers can be had from AMK, as well as from most Mustang suppliers. AMK actually sells a kit with all the retainers and clips in one unit.
Connectors don't seem to have an easy solution, at least from what I've found. One solution is to use the repro harnesses (made by AMP), which are actually quite good, and include all the connectors for mating with the original underhood equipment.
Carl
'70 Boss 302
'70 M-Code Vert w/ Shaker
'85 1C SVO
'11 Shelby GT-500
'02 Excursion (7.3l)
'04 Expedition
'07 Speed6
chpierce is offline
post #4 of 8 (permalink) Old 10-03-2010, 10:18 PM
guy48065's Avatar
It's nearly impossible to take enough pictures to sow the amount of detail you need--black taped harnesses on black paint are hard to follow in a picture. The factory wiring diagrams are a great help but can be confusing if your car is far away from correct. Going to some car shows or large cruise-ins can be a huge help. Especially if you meet someone local with a similar car that'll let you spend some time studying it
My previous pony was a 70 Mach1:
65 C-code with 4-spd & 4-bbl swaps.
guy48065 is offline
post #5 of 8 (permalink) Old 10-03-2010, 11:13 PM
As Guy said, following black tape wrapped wires in a black engine compartment can be difficult:
Even if you're going the custom route, I think the Electrical Assembly Manual is a great resource ($19 from NPD) since it has the wiring diagrams as well.
If there's any specific area you need info on, let me know and I'll try to describe it/shoot a pic of it.
Carl
'70 Boss 302
'85 1C SVO
'11 Shelby GT-500
'04 Expedition
'07 Speed6
chpierce is offline
post #6 of 8 (permalink) Old 10-04-2010, 03:55 AM
JimNiki's Avatar
This is a similar pic but with most wiring hidden under the guards...
I'd rather have a bottle in front of me than a frontal lobotomy...
JimNiki is offline
post #7 of 8 (permalink) Old 10-04-2010, 08:43 AM Thread Starter
Thanks Carl and all,
Carl that is the look I am going for in my engine compartment, looks neat and correct. The only difference in mine would be I don't have a shaker hood and there is wiring that goes to my fake scoop for the directional lights.
I will pick up that manual it should be a big help. The area I am looking for a good photo of is the gauge and coil harness and the charging harness. I think there are some clips on the valve cover for the gauge harness, not sure on the charging harness, seems most cars have it tied to the shock tower support not sure.
Kenzo is offline
post #8 of 8 (permalink) Old 10-04-2010, 10:41 AM
The charging harness goes out under the cowl support. There are two retainers that connect to the bottom of the brace, and another that connects to the shock tower. The extra harness is strapped to the apron below the voltage regulator. I'll see if I have a pic.
The engine feed harness has three clips, one on the top rear bolt of the drivers side valve cover, then two more on the top bolts of the passenger side valve cover.
On a Cleveland, the oil pressure sensor is on the rear of the engine, so the front of the harness looks the same (mine has a Pertronix integrated for daily driving, so there is actually an extra wire in that pic.) It comes up the passenger side valve cover, then splits. The coil is properly mounted in front of the passenger side valve cover.
The Electrical manual shows the hood mounted indicator harness, as well as the above.
The only difference with a shaker is an extra pair of vacuum hoses, and a different tee on the front of the engine.
Carl
'70 Boss 302
'85 1C SVO
'11 Shelby GT-500
'04 Expedition
'07 Speed6
chpierce is offline
