Alternator One-wire Conversion Kit - Vintage Mustang Forums
 1Likes
  • 1 Post By 1-18-68
post #1 of 12 (permalink) Old 10-05-2010, 10:02 AM Thread Starter
Ponyboy289's Avatar
I was thinking of ordering one of the kits that Mustangs Plus sells Mustang Parts from Mustangs Plus :: Electrical :: Voltage Regulators :: 1965-66 Single Wire Conversion System
for this conversion. I also noticed a kit manufactured by a company called Victory Lap, kit no. OWFD40-60 that's sold online in a couple of places (may be the same kit sold by Mustangs Plus and NPD). Anyone have any experience with these kits? I have a remanufactured 55A alternator in my '65 and was wanting to eliminate the voltage regulator and wiring to it.
Puddle of oil? What puddle of oil? That's just sweat from all that horsepower! - Mr. Used-Car-Lot Salesman
1965 Poppy Red, "C" code, San Jose Hardtop
MCA #45799
Mississippi Coast Mustang Club
www.mscoastmustangclub.com
Ponyboy289 is offline
post #2 of 12 (permalink) Old 10-05-2010, 03:36 PM
PA Performance sells a 1G to 3G conversion kit that looks like the original regulator so you can retain the original wiring.
PA Performance 1G to 3G
68LimeGold is offline
post #3 of 12 (permalink) Old 10-05-2010, 04:28 PM
Before you decide to convert to a one wire alternator, read this article.
Catalog
cat7195 is offline
post #4 of 12 (permalink) Old 10-05-2010, 08:07 PM
Grabber70Mach's Avatar
+2 on the 3G.
Grabber70Mach is offline
post #5 of 12 (permalink) Old 11-13-2010, 07:20 AM
msmith's Avatar
Originally Posted by Grabber70Mach View Post
+2 on the 3G.
Make that +3. Easy, reversible and works great. They sell a 95A 3G alternator.
msmith is offline
post #6 of 12 (permalink) Old 11-13-2010, 08:01 AM
miketyler's Avatar
Am also interested in running a higher amp alternator to run headlights, electric fans, ac, power windows, etc. I read the article and found some interesting points. From the notes above, I presume not all the 3G alternators are 1-wire application?
miketyler is offline
post #7 of 12 (permalink) Old 11-13-2010, 08:53 AM
Catalog
Just to throw my 2 cents in this:
What the author failed to mention: That you can still have a warning light with a one wire setup. The damage that can happen with a loose connection and sensing past it. One wire alternators are not hard to find.
ivancaicedo237 is offline
post #8 of 12 (permalink) Old 11-13-2010, 09:31 AM
jguinta's Avatar
or just put a GM unit in - they are one wire.
John Guinta
1965 GT350 comp clone
jguinta is offline
post #9 of 12 (permalink) Old 11-13-2010, 11:34 AM
Thumbdown
GM + Ford = inbreeding, bad very bad.
post #10 of 12 (permalink) Old 11-13-2010, 04:13 PM
nba1341's Avatar
Tuff Stuff makes 1 wire and original style high amp alternators in the factory original case
1965 Mustang Fastback 302
2010 Grand Marquis
nba1341 is offline
post #11 of 12 (permalink) Old 11-13-2010, 04:42 PM
And when it breaks down can you get one at your local auto parts store, I'll bet you couldn't find one. Bet you could find a 3G at your local parts store though even on a weekend.
post #12 of 12 (permalink) Old 11-13-2010, 06:06 PM
1-18-68's Avatar
Interesting article. I have used 3 wire GM/Delco alternators to upgrade a number of British Sports Cars as well as some early tractors and one bulldozer. They work great and run about $40 at the chain auto parts stores. Wiring a 3 wire alternator is no trick. I would probably stay with an uprated Autolite unit in my Mustang, which is what I did in my '68. Write me off as being "old school".
Just be sure when you install a 100 amp alternator you have installed wiring to go with it or you risk burning your ride to the ground.
russ
vista likes this.
1-18-68 is offline
