Electrical connector pin removal tools or techniques - Vintage Mustang Forums
post #1 of 7 (permalink) Old 12-18-2010, 08:55 AM Thread Starter
miketyler's Avatar
I need to remove female connnector pins from a 71 turn signal plug steering column harne. Am having no luck using a fine screwdriver to depress the retainer tang to release them. I don't mind buying tools for this, what do you guys use for this? Am trying to avoid cutting and splicing wires back in.
Saw this kit from Summit, anyone use this for such tasks?
Pico Pin Extraction Tool 0660PT - eBay (item 330500751119 end time Dec-25-10 15:39:45 PST)
miketyler is offline
post #2 of 7 (permalink) Old 12-18-2010, 09:08 AM
kenash's Avatar
Hi,
I know they can be a PITA! For the money, I guess it's worth a try. Do you have a Harbor freight in your area to check?
Good Luck!
Ken ..
64 1/2 Poppy Red too!, Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Severna Park, MD
kenash is offline
post #3 of 7 (permalink) Old 12-18-2010, 09:17 AM
Joe
NPD has a tool that works very well.
'65 Coupe, 302, Autolite 4100, C4, 3.00
Joe is offline
post #4 of 7 (permalink) Old 12-18-2010, 09:24 AM
ylexot's Avatar
I use an assortment of dental picks.
Formerly of the Permanently Addicted...
Let it be known that I do not street race or condone that sort of thing
- unless the 'b@stard deserves it.
Someone takes his pants off and the rafters knock
Rock is dead they say
Long Live Rock!
67 conv. 289 4spd(mine), 67 coupe 289 Export(swmbo's)
ylexot is offline
post #5 of 7 (permalink) Old 12-18-2010, 09:36 AM Thread Starter
miketyler's Avatar
Spot on, my friend. Its their PN 957-2. Even the description specifies it works for turn signal plug pins. Good price too, thanks!
Looks similar if not identical to the Snap-on one here:
post #6 of 7 (permalink) Old 12-18-2010, 11:28 AM
GT289's Avatar
If you go to an electronics supply store (Radio Shack doesn't count), you
can get a professional pin removal tool for pretty cheap. The inside diameter
of the outer tube does what the Summit tools do but there's an inside piece
on the pro type tools that actually pushes the pin connector out of the plug.
It's this design of tool.....the one's I have are 3-4 bucks though.
CONTACT EXTRACTION TOOL - 305183
- Douglas Adams
GT289 is offline
post #7 of 7 (permalink) Old 12-18-2010, 12:08 PM Thread Starter
miketyler's Avatar
Yes, seems like those we used in my aviation days were like that; they had an inner plunger with a ball knob tn the end that would actually push the pin out of the socket for you. I may take a trip to my local Fryes on this and see what they have. I think I have seen the Lisle unit I have pictured above at some local parts stores.
