how to tell the difference between 289 and 302? - Vintage Mustang Forums
post #1 of 15 (permalink) Old 01-10-2011, 10:11 PM Thread Starter
QuickV8.com's Avatar
previous owner told me that my 67 had a 289, and he also gave me a 302 engine supposely. they're identical. one says 302 on the head. other one doesnt.
ModifiedBeasts.com
2004 SVT Cobra 281 M6 · 498.5 RWHP · Stiegemeier Stage 4 Ported M112 Supercharger·Steeda 2.81 Pulley·MotoBlue Pulleys+more
Other Toys: 1967 Mustang 306 M5·1979 Firebird Formula 403 A4·1993 Camaro Z28 355 A4·1997 Mustang GT 281 M5·1987 Mustang GT 302 M5
QuickV8.com is offline
post #2 of 15 (permalink) Old 01-10-2011, 10:17 PM
22GT's Avatar
What are the casting codes on the block above the starter? Be aware, though, the some late 289 engines were assembled with 302 blocks.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #3 of 15 (permalink) Old 01-10-2011, 11:38 PM Thread Starter
heres a pic
ModifiedBeasts.com
post #4 of 15 (permalink) Old 01-11-2011, 06:19 AM
The picture doesnt say anything.
You need to look for the cast numbers on the engine.
Those numbers are located near the place where the startmotor is .
Zipper is offline
post #5 of 15 (permalink) Old 01-11-2011, 06:43 AM
22GT's Avatar
True-
That photo could be a 289 or a 302, and there would be no way to tell. Really.
The only difference between the 289 and 302 is the 302 has a 1/8" longer stroke.
Experts have screwed this up.
It would be possible to rebuild a 289/302, and not know which it was.
22GT is offline
post #6 of 15 (permalink) Old 01-11-2011, 05:43 PM
Here's the block in my original June 67 289 engine. If I wasn't positive it was a 289, I would be fooled. The heads are marked as 289.
68 GT Vert - J Code (1st car I ever drove in '73, dad bought it in '71)
67 C Code Vert Sports Sprint (1st car I ever bought in '75)
06 Vista Blue with Pony Package (1st Mustang I ever bought new)
MCA #49294 Grayson, GA (Atlanta)
daves67ss is offline
post #7 of 15 (permalink) Old 01-11-2011, 08:35 PM
ylexot's Avatar
Keep in mind a lot can happen in 45 years or so. How many guys have built roller 302's into 347's? External casting codes don't tell that story. Pull the pan and look for the crank code (1U, 2U) if you really care. Don't see what difference it would make. The internals are the only thing specific to a 289 or 302, and they seem to be in place already.
Formerly of the Permanently Addicted...
Let it be known that I do not street race or condone that sort of thing
- unless the 'b@stard deserves it.
Someone takes his pants off and the rafters knock
Rock is dead they say
Long Live Rock!
67 conv. 289 4spd(mine), 67 coupe 289 Export(swmbo's)
ylexot is offline
post #8 of 15 (permalink) Old 01-13-2011, 12:21 AM
PonyDoc's Avatar
Thumbup 289 vs 302
Date codes are the best bet. 68 and up- 302. You can build a 289 from a 302 and vice versa, but make sure you use the correct push rods. I had a 302 block done as a 289 w/ 289 heads, but they used 302 rods- snapped 3 rocker arms before we found the problem! They are .13" longer! Unless you need a show dated engine ( like they're going to pull the starter to see date codes, the water pumps and castings on the housing just behind the pump will show the difference. Find a mexican 302 and build a hi-po!
PonyDoc is offline
post #9 of 15 (permalink) Old 01-13-2011, 09:53 AM
yelostang's Avatar
Many late 68 C Code 289's had 302 cast into the block...in the lifter galley. Had one and it had the vin* stamped on the block just forward of bell housing and behind intake manifold.
yelostang is offline
post #10 of 15 (permalink) Old 01-13-2011, 01:33 PM
wilit's Avatar
Why don't you just measure the stroke to see if it has a 289 or 302 crank? Looking for casting codes isn't going to tell you much.
wilit is offline
post #11 of 15 (permalink) Old 01-13-2011, 02:00 PM
Crazy
Great idea! Trick is do it with the heads and pan on!
My '64 1/2 vert. Ordered May '64. D code 4 speed, handling package, caspian blue, accent group, Ford blue manual top.
'68 vert. driver. Owned since Apr '78. C code AT, AC, PS, P disc B, PT lime gold, standard black interior and top. NOS RF fender and left quarter.New top and folding glass.
slim is online now
post #12 of 15 (permalink) Old 01-13-2011, 05:05 PM
wilit's Avatar
This is one of those, you can't have your cake and eat it too type scenarios. If the OP really wants to know, he's going to have to take a head off and measure it.
Do cranks even have casting numbers? I don't know that I've ever seen one on a crank. Then again, I've never looked for one.
wilit is offline
post #13 of 15 (permalink) Old 01-13-2011, 05:16 PM
22GT's Avatar
Just codes. The 289 would be "1M", and the 302 would be "2M", or "2MA". Pull the oil pan and you'll know.
22GT is offline
post #14 of 15 (permalink) Old 01-13-2011, 05:33 PM
Does it matter?
Sense is not as common as you think.
17" MB Old School wheels from discount tire (a lot of people ask)
OCHOHILL is offline
post #15 of 15 (permalink) Old 01-13-2011, 07:02 PM Thread Starter
ok thanks. i'm about to check.
ModifiedBeasts.com
