Edelbrock 1405 - Help - Vintage Mustang Forums
post #1 of 14 (permalink) Old 02-12-2011, 07:11 PM Thread Starter
Has anyone installed a Edelbrock 1405 on a 1964 1/2 289 4V engine ? Any pics would be great.One question that I have is that the mustang now has a 1 inch spacer plate where the PCV valve connects and the Edelbrock has a connection on the front of the carb for the PCV connection. Should the PCV connection on the carb be plugged ?
64.5 Coupe
289 Automatic
LeeR is offline
post #2 of 14 (permalink) Old 02-12-2011, 07:21 PM
MagMustangs's Avatar
The Eddy 1405 is a Spread-Bore Carb and requires a Spacer that allows the Secondaries to fully open. I use to run one on a 65 289 4V Motor and took me forever to figure out why it didn't run right. The Secondaries were not opening, they were hitting the Intake Manifold, because I did not have the correct Spacer. If I remember correctly, The Spacer does not have the Port, which should eliminate your problem. IMHO .
MagMustangs is offline
post #3 of 14 (permalink) Old 02-12-2011, 07:30 PM
Madmustangs is incorrect. The 1405 is a square bore carb not a spread bore,even though the secondary butterflys are slightly bigger than primarys. Spread bores are like you Q-jet carbs, which require an adaptor plate if running a square bore intake. As far as your spacer you have, you can plug the PCV port on it and run the one on your Carb in front. The one in the back is for power booster
algsey is offline
post #4 of 14 (permalink) Old 02-12-2011, 07:36 PM
kenash's Avatar
+1 for all that's been stated. I still have my 1405 I used on my D code block. They run and work well with a 1/2" phenolic spacer and tuned with a vac gauge. I think I purchased it from Jegs.
Happy Motoring!
Ken ..
64 1/2 Poppy Red too!, Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Severna Park, MD
kenash is offline
post #5 of 14 (permalink) Old 02-12-2011, 10:18 PM
tom991's Avatar
Are you using a stock intake manifold under the 1405?
tom991 is offline
post #6 of 14 (permalink) Old 02-12-2011, 10:39 PM
lunarweasel's Avatar
I have a Edel Performer 289 intake under one, works perfectly. No tuning required.
5R07C, 4spd Toploader, Black Std Interior, Originally Ivy Green, Edelbrock 500cfm-4V on Perf 289 Intake,
Hurst Super Shifter, Baer SS4 Disc Brakes (4-piston, Aluminum, USA Made),
New Front Susp. w/Shelby Drop, New Steering, Drake Export Brace / 1" Sway Bar / Monte Carlo Bar, Mallory Unilite Distributor
lunarweasel is offline
post #7 of 14 (permalink) Old 02-13-2011, 05:18 PM
yelostang's Avatar
Have a 500cfm Edelbrock, and vac advance to front of carb. PCV into back of carb, Power brake and trans modulator to a block on the intake, at the rear. Have a 1/4" phenolic on a Weiand dual port intake.
yelostang is offline
post #8 of 14 (permalink) Old 02-13-2011, 07:07 PM Thread Starter
Stock Manifold
64.5 Coupe
289 Automatic
LeeR is offline
post #9 of 14 (permalink) Old 02-13-2011, 07:13 PM
kenash's Avatar
Originally Posted by LeeR View Post
Stock Manifold
I guess you have your answer at this point then.
Happy Motoring!
Ken ..
Severna Park, MD
kenash is offline
post #10 of 14 (permalink) Old 02-13-2011, 09:26 PM
I have one on my 66 with an RMP manifold. The carb was just a little rich from the factory according to my wideband O2. I moved the jets and rods one step down leaner and used the orange spring and it runs strong and 16 MPG.
A66auto is offline
post #11 of 14 (permalink) Old 02-14-2011, 12:41 AM
I'm running a 1406 on a stock intake. I'm also using the factory spacer with the PCV. I used plug in the Edelbrock PVC location. I had to richen mine 1.5% but you should be fine with stock jetting since the 1406 is an emission style carb that's jetted leaner. I also cut the end off the stock carb linkage, threaded it with 10/32 threads and installed a rod end I got at Grainger
Tom
People told me I need help with my drinking problem. So I hired a bartender.
Huskinhano is online now
post #12 of 14 (permalink) Old 03-05-2011, 09:57 AM Thread Starter
Update : Finally have everything worked out with this Edelbrock 1405 and I love it ! I have owned this car now for over 10 years and it has never run and drove better.
I am still using the stock fuel pump without any over-pressurization isssues.
Thanks for everyone`s input and suggestions.
64.5 Coupe
289 Automatic
LeeR is offline
post #13 of 14 (permalink) Old 03-05-2011, 10:07 AM
Great!
post #14 of 14 (permalink) Old 03-05-2011, 10:21 AM
miketyler's Avatar
Thanks for posting this, glad it is running fine for you. I have 351C in my 70 Mach and plan to put an Edelbrock Performer intake with the 1406 (electric choke version of the 1405). Will I have to run a spacer plate for this carb? I believe this is a pic of the manifiold I plan to use...
miketyler is offline
