Borgeson conversion and bump steer - Page 2 - Vintage Mustang Forums
Old 10-09-2011, 02:33 AM   #16 (permalink)
supershifter2's Avatar
Originally Posted by 64coupe View Post
Borgeson recommends not using a u-joint due to significant vibrations transferred through them.
obviosly no one at Borgeson ever drove a 65-66 mustang with the SOLID steering shaft that gives you the best road feel along with the noise and vibrations.
supershifter2 is online now   Reply With Quote
Old 10-09-2011, 02:47 PM   #17 (permalink)
yelostang's Avatar
Exactly. Funny - that Borgeson never mentions anywhere - huh?
Like Some rack and pinion companies, hedging and giving ambiguous answers when asked about increases in turning radius! Sort of like don't ask don't tell.
yelostang is offline   Reply With Quote
Old 10-12-2011, 01:18 AM   #18 (permalink)
I think that a custom or modified Pitman arm may be the way to go. Anyone have a source for one?
I think you can buy the longer Shelby quick steer idler arms seperately, so one thing you could do is to cut a stock pitman arm apart and weld it back together with the drag link mounting point further out and up (with some extra steel in between the two ends, obviously). Of course, such a project requires good welding skills.
In the end, everything is fixable, but I thought the Borgeson modified these boxes so that everything lined up correctly, but apparently not. I assume they respline the shaft to fit he Ford pitman arm, so one wonders why they don't make it shorter as well, while they are at it? I guess that requires modifications to the housing that are somehow not possible.
Helmantel is offline   Reply With Quote
Old 10-12-2011, 08:00 AM   #19 (permalink)
GT289's Avatar
We "custom" assembled the trick pitman arms. You will need far above
average welding and metallurgy skills to accomplish that feat safely.
If a pitman arm fails in operation..... well you get the picture.
ex-Global West GM
1991-1994
- Douglas Adams
GT289 is offline   Reply With Quote
Old 02-04-2013, 04:52 PM   #20 (permalink)
HyePo66's Avatar
I actually repalced my pitman and Idler with shelby cobra style... longer pitman and idler = quicker steering response and installed them on the car we did the Borgesen box in (also did tilt wheel later after i installed the cut down factory steering column). I have not anticipated any problems with bumb or anything else. it all looks as though it should be fine... car not yet on road...
I do remember my "kit" came with a new manual draglink although I had power steering (and still do)..
Basically
Borgesen box
Borgesen drag link
Cobra Automotive pitman and roller idler
here's my install 1966 Mustang RestoMod
1966 Mustang GT RestoMod Project: 307c.i.d.,Holly 600 4brrl, TrickFlow Heads, Power Disc Brakes, Integral Power & Tilt Steering, AOD, 9" 3.50 posi rear end & a bunch of other stuff.
Project start date 1999. Completion date... fagidaboudit!
First Mustang, 1966 I-6 w/Pony interior (bought in 1980 for $600.00 - sold in 1984 for $600.00)
http://www.myrestomodmustang.com
Like the MyRestoMod project on Facebook:
http://www.facebook.com/pages/1966-M...88268267888907
HyePo66 is offline   Reply With Quote
Old 02-04-2013, 05:17 PM   #21 (permalink)
3 rack systems have been "refitted" to the original PS in the past two years from owners
Simply, they don't want to have a wreck with the cockeyed turning.
Dan @ Chockostang
CHOCK is offline   Reply With Quote
