Originally Posted by Jays66gt
6Z A is stamped on the foot...
According to Mannel's book, That is a C6ZF-A which is the the earlist revision of that C6ZF. It is definitely the correct carb body for a 289 4V without smog. Appendix C says in #16, All 67-69 had "pipe threads" on the in-line filter. Prior ones had "tube-type" threads and refers to page 7-10 photo # 7C4. In THAT picture, if you look at the "c" one, YOUR carb body is definitely the one like mine for the in-line Motorcraft FG-15. (the right-hand one in picture (e), with "1966" printed above it.
I don't know what to tell you. Either the threaded part of your filter is too short, or a PO has "monkeyed" with the bevel inside that carb body, which I doubt.
All I know is, I had leaks with 2 locally purchased filters, due to the same issue you are having, and then I bought an NOS Motorcraft one off Ebay that was made in the 70's and it fit right on the bevel and the leak stopped.
Now about Teflon tape... YOUR threads don't taper like pipe threads. Pipe threads get tighter as they go deeper and teflon tape works real well on them.
YOUR threads are uniform diameter all along and if you put tape on them, the threads won't SQUEEZE the teflon into the voids like pipe threads do.
You MAY be able to get it to seal, who knows?
If you screw it all the way in WITHOUT a gasket, will it bottom out?
My thought is...you still haven't got the filter that is made right. If it were me, I'd chuck the filter in the lathe and remove 1/16 of the hex-area flat, so it would screw in deeper.
My gut tells me that if you got an NOS one off Ebay, it would seal, but I can't prove that.
