Done! Just removed cover and gasket. Gasket has two holes, about 3/8" in diameter. these holes were at the front end of the trans. cover. flipped gasket around 180 so they were at back end and re-covered. Hopefully that will be the end of this issue! FYI there was a bit of oil lodged between the cover and gasket, could see how it could migrate out the vent hole. Again thanks to all those whose input made this repair possible!
Mike in Spudland
"Would you like baked, mashed or fries with that?"
'Genny' 1964 1/2 coupe Cascade Green
'Jessie' 1966 coupe Arcadian Blue
Reason: extra tid bit
