Weird but car won't run hot - Vintage Mustang Forums
post #1 of 6 (permalink) Old 04-27-2012, 08:45 PM Thread Starter
For some odd reason my car will not get over 130 degrees what can be the cause of this and will it hurt running so cold all the time.....its the motor in my 69 efi.....The hottest it has ever run was 160 stuck in traffic for 30 minutes in 80 degree weather with the A/C on?
On the way home tonight it was about 60 outside and the hottest it would get was 115? what gives
Jgroce1985 is offline
post #2 of 6 (permalink) Old 04-27-2012, 09:02 PM
tooponies's Avatar
What type of gauge are you going by. The factory gauge in my 65 read colder than I wanted it to run. I installed a mechanical gauge and found that it was running at 190.
tooponies is offline
post #3 of 6 (permalink) Old 04-27-2012, 09:07 PM
Kelly_H's Avatar
What thermostat have you got in there? And have you verified that it's not stuck open? That could cause you to run a little chilly.
Gauge could also be at fault, as tooponies said.
Calamity Jane 1966 Modified Fastback - Driven semi-daily!
Wrecked and rebuilt even better
289 v8, 4-speed, 3.25 9" rear, goodies and stuff.
See my travel blog here for my adventures: http://calamityjaneroadtrip.blogspot.com/
2014: 10,051 mile, 2-month-long road trip around America
2015: 3,000 mile trip to Knotts in CA, CO to East Coast, an engine rebuild or two
2016: East Coast to TX, Hot August Nights, more trips to the East Coast
2017: Several long trips in the works! Stay tuned
Kelly_H is offline
post #4 of 6 (permalink) Old 04-27-2012, 09:54 PM
Blue Blood's Avatar
Send a message via MSN to Blue Blood
To answer the question regarding whether the low temp is; number one is the lack of combustion efficiency at the reduced temp, unburnt fuel can wash cylinder walls which reduces lubrication, reduced compression because the anticipated expansion of the block and other parts does not occur, and many would disagree that even 160* is too low (unless you're fighting detonation).
1995 GT Convertible - Laser Red - 331 stroker, Kenne Bell 2.2 - 415 RWHP 396 RWTQ
2002 Corvette Z06 - 410 RWHP 410 RWTQ
1968 Mustang Fastback .... Rustbucket slowly being reborn
Blue Blood is offline
post #5 of 6 (permalink) Old 04-27-2012, 09:56 PM
machyoung's Avatar
I would put a mechanical gauge on to validate accuracy of your existing!
66 GT Coupe
03 Mach 1 - (10.98 @ 120.64)
68 Torino GT Convertible (Christy)
68 Ranchero S Code
machyoung is offline
post #6 of 6 (permalink) Old 04-27-2012, 10:11 PM
or buy a noncontact infrared thermometer for 20 bucks and shoot the engine and compare readings. Gauges are notoriously inaccurate. Even a mechanical Mr. Gasket thermostat/radiator cap would get you closer to the truth
Jeff73Mach1 is offline
