Need pics of 4-speed speedo cable routing...please - Vintage Mustang Forums
Old 05-03-2012, 07:50 PM   #1 (permalink)
Phydeauxman's Avatar
Default Need pics of 4-speed speedo cable routing...please
Finally got the correct speedo cable for my 65 and got the hole in the floorboard drilled today. Installed the cable from below and routed it up to the instrument cluster.
Now all I need is to know the proper routing under the car. I think I have all of the parts I need to properly attach it but since my car came with a 3-speed originally and did not have any speedo cable at all when I bought it...need a visual on how it should be routed.
- 65 2+2 Fastback 289 4V 4-Speed (Mostly stock, under restoration)
- 68 Coupe, (32000 original miles), 2V C4. Resto-modding, TCI suspension, 5.0 EFI conversion w/5 speed
Phydeauxman is offline   Reply With Quote
Old 05-04-2012, 05:58 AM   #2 (permalink)
Anyone?
Old 05-04-2012, 08:29 AM   #3 (permalink)
You need a 7/8" hole about 1" from the firewall on the curved part of the trans tunnel in the 1 o'clock position from the gas pdeal
Tom
Rehab is for quiters!
Huskinhano is offline   Reply With Quote
Old 05-04-2012, 08:43 AM   #4 (permalink)
Thanks for the reply. I have already done that part...I need pictures of how it is properly routed under the car from where it comes out the hole to the trans connection on the right side of the car.
Old 05-04-2012, 08:59 AM   #5 (permalink)
Do a search there are several photos there.
65fstbpieces is offline   Reply With Quote
Old 05-04-2012, 09:14 AM   #6 (permalink)
It goes through the trans tunnel where the trans tunnel meets the firewall near the drivers' right little toe. It clips to the RH toe board where the passenger's left toes are, and to the right side of the trans crossmember just before entering the transmission. All of these clips are available. The Carpenter cable is the correct length (very few are even close) and has the factory-correct foam seal for the hole in the floor
Hawthorne is offline   Reply With Quote
Old 05-04-2012, 09:33 AM   #7 (permalink)
Thanks for the reply. Have done quite a bit of that so far with no luck. So either my search prowess is lacking (very possible) or I have not found photos that are any help.
Old 05-04-2012, 09:35 AM   #8 (permalink)
Thanks for replying. I have all the clips...got them from VCM. The things I was hoping to see in pictures is the over/under positioning around the exhaust pipes and the transmission crossmember.
Old 05-04-2012, 09:57 AM   #9 (permalink)
ivygreen65's Avatar
Phydeauxman,
If you look on the transmission tunnel near the accelerator pedal, you'll see the hole where the speedo cable goes through the floor pan.
I routes to the right side of the car. There is a clip on the passenger side toe board.
It comes down and through the transmission crossmember and into the right side of the transmission.
I think these will help you get it installed correctly.
65 Mustang Convertible 289 C-code
Rangoon Red with White w/Red Appointments Deluxe Interior
ivygreen65 is offline   Reply With Quote
Old 05-04-2012, 04:01 PM   #10 (permalink)
ivygreen65...thanks a bunch...that is exactly what I needed.
