Attaching the Choke pipe fitting to carb - Vintage Mustang Forums
Old 05-08-2012, 07:40 AM   #1 (permalink)
Default Attaching the Choke pipe fitting to carb
Trying to get the threads on the choke "outlet" tube to mate with the themostatic choke housing at the carb and I am finding that the pipe itself hits and the threads are not able to match up and be tightened. Not sure what is going on here?
SunlitGold68 is offline   Reply With Quote
Old 05-08-2012, 11:09 AM   #2 (permalink)
ylexot's Avatar
2V, 4V, Factory carb?
Formerly of the Permanently Addicted...
Let it be known that I do not street race or condone that sort of thing
- unless the 'b@stard deserves it.
Someone takes his pants off and the rafters knock
Rock is dead they say
Long Live Rock!
67 conv. 289 4spd(mine), 67 coupe 289 Export(swmbo's)
ylexot is offline   Reply With Quote
Old 05-08-2012, 11:13 AM   #3 (permalink)
bryancobb's Avatar
If you have one of the repops, It will never fit. The brass ferrule is all wrong. I compared it to my ratty looking OEM one and it was totally different. I don't remember what I did to fix the situation, but I remember the ferrule didn't work as it came.
bryancobb is online now   Reply With Quote
Old 05-08-2012, 11:23 AM   #4 (permalink)
22GT's Avatar
The pipe inserts into the housing, then the compression fitting slides into place. I have never had the slightest trouble with repro tubes. The compression fitting is a common item, available in any decent hardware store or auto parts store.
Amateur restorer. (Well, once in a while I have been paid for it)
22GT is online now   Reply With Quote
Old 05-08-2012, 12:00 PM   #5 (permalink)
I second 22GT's statements. A couple of times, I've had to loosen the carb in order to get the nut started, but that's all. Check to make sure the thread on the choke housing is in good shape. Have seen some cross threaded examples.
PrecisionTrans is offline   Reply With Quote
Old 05-08-2012, 03:49 PM   #6 (permalink)
bryancobb's Avatar
All I know, is my OEM one had a bulge, it didn't have a compression ferrule. The brass compression ferrule WILL NOT go up in the taper far enough for threads to start because the carburetor body on my C6DF-B had a taper inside, that had the geometry of the bulge in my OEM one. It didn't match the brass ferrule.
I was tempted to taper the inside differently but I wound up modifying the ferrule in the lathe.
Old 05-08-2012, 06:23 PM   #7 (permalink)
can you buy that brass housing that the tube screws into... the one pictured in the photo above, left side. Is this a common item at NAPA or another car parts place.
Old 05-08-2012, 06:29 PM   #8 (permalink)
22GT's Avatar
Yes.
Strange. I have installed many, and never had a problem unless the threads were damaged on the choke housing.
The 1V, 2V, and 4V all used the same fitting.
Old 05-08-2012, 06:35 PM   #9 (permalink)
Jays66gt's Avatar
I purchased this set from MU:
Mustangs Unlimited - The Premier Source for Mustang, Shelby and Cougar Parts and Accessories
Fit my 4100 1.08 carb with no issues what-so-ever.
1966 GT coupe, A code 289, 4 speed.
Jays66gt is offline   Reply With Quote
Old 05-08-2012, 07:38 PM   #10 (permalink)
bryancobb's Avatar
I'm a little confused. The picture you posted looks like copper tubing and fittings from a hardware store.
My repop set had a steel line, with a female brass nut and the ferrule. It DID NOT have the brass male fitting. My heat coil chamber had it's inlet cast into its' body, including the male threads and the taper inside, for the bulge on my OEM steel line??
Old 05-08-2012, 07:47 PM   #11 (permalink)
bryancobb's Avatar
Don't pay attention to the 1100. Just look at the choke heat chamber. The place where mine screws on looks just like this. The ferrule takes up almost 1/4 of space and the brass nut is only threaded for a little more than that inside. It won't even screw on a full turn.
Old 05-08-2012, 08:08 PM   #12 (permalink)
22GT's Avatar
22,
The tube in the photo is copper, the one on cars is steel. However, the compression ring, and retaining nut, are absolutely identical to those used on cars. The double-threaded brass item is often used to repair stripped cast-on threads on choke housings. Whether hardware store or Ford parts bin, the brass parts are identical.
Old 05-09-2012, 01:38 AM   #13 (permalink)
You have to make sure the pipe is going straight into the fitting on the carb. If it is off even a little it makes it very difficult to start the brass fitting.
67t5ponycoupe is offline   Reply With Quote
