engine problems need help!!!! - Vintage Mustang Forums
Old 05-08-2012, 10:21 PM   #1 (permalink)
Question engine problems need help!!!!
1968 mustang 351 windsor, cam specs are 496 intake 520 exhaust 290/300 duration
edelbrock performer rpm cam and high rise intake
holley 750 single pumper 4160 model
engine is running fine, but when i let off the throttle it loads up and is dumping tons of smoke out of the exhaust, all plugs are a gold color it only loads up when letting off the throttle, i am out of ideas i cannot figure out why the car is doing this somebody help
SBM POWERED
MUSTANG
agross2011 is offline   Reply With Quote
Old 05-08-2012, 10:28 PM   #2 (permalink)
6t9mach1's Avatar
What color is the smoke?
~Ryan~
1969 Mach 1- 357w: 11:1 compression, ported Canfield heads, FTI billet solid roller cam, Vic Jr., 850 Mighty Demon
Full manual AODE transmission w/ 9.5" Art Carr converter; 4.11 detroit locker
http://www.cardomain.com/ride/2554478
6t9mach1 is offline   Reply With Quote
Old 05-08-2012, 10:56 PM   #3 (permalink)
smoke is black, its clearly smoke from getting too much gas
SBM POWERED
MUSTANG
Old 05-09-2012, 12:33 AM   #4 (permalink)
Timing issue??
joorloop is offline   Reply With Quote
Old 05-09-2012, 01:33 AM   #5 (permalink)
Le Singe Psycho's Avatar
Maybe a float isn't closing (or two).
Le Singe Psycho is offline   Reply With Quote
Old 05-09-2012, 06:11 AM   #6 (permalink)
69Mach1_itch's Avatar
Letting off the throttle changes the vacuum state - from low to high. How is the distrubutor advance line run - from full port vacuum beneath the carb, or part port vacuum above the float bowls? What happens if you block off the advance and retime the engine?
69Mach1_itch is offline   Reply With Quote
Old 05-09-2012, 07:04 AM   #7 (permalink)
mjb1032's Avatar
Have the valve cover oil baffles been removed?
Slowly restoring and improving dads '68 289 Coupe...
mjb1032 is offline   Reply With Quote
Old 05-09-2012, 06:56 PM   #8 (permalink)
the timing at idle with vacume advance unplugged was at about 10 degrees btdc and with the vacume hooked back up at 4000 rpm it shot at about 37 degrees, how could i block off the advance the timing needs to advance no matter what, it is a vacume advance distributor only not mechanical.
and the valve covers are in stock condition...why?
SBM POWERED
MUSTANG
