late model inline six head questions - Vintage Mustang Forums
Old 05-10-2012, 08:22 PM   #1 (permalink)
cjfrehlich's Avatar
Send a message via Skype™ to cjfrehlich
Default late model inline six head questions
okay, so im getting a late model log head from my machine shop because ive brought in two cracked ones already and im soooooooo tired of seeing the stang sitting there being undriven I still need to get the carb spacer thing that goes between the carb and the intake bore. my question is, can i use my carb that i have that i used on my 65 head, its a holley 1940 service replacement carb, its a good carb too. or do i need a carb with a larger bore? the holley is meant for the smaller bore head. i hope im providing enough info
1966 mustang, light metallic blue, 200 ci inline six
cjfrehlich is offline   Reply With Quote
Old 05-10-2012, 10:37 PM   #2 (permalink)
It should work as long as the bore opening on the carb is smaller than the intake bore. Your new intake should be just under a 1 3/4 bore and your carb should be 1 1/2.
But if you are thinking carb upgrade in the future I would have the intake machined for the two barrel since it is off already. You will get significant hp and tq increase. Check out classic inlines tech info. Yes I just recently did all of this research....I have the weber 38/38 on the way!
Brandon
1968 mustang coupe
Inline 6 by cotrell racing (Tpis)
Clifford cam, 2 barrel weber carb, large log head, 1-6 roller rockers, ported, port devider, duel out header, duel exaust (with turbo mufflers) new dash pad, bezels, v8 suspension and drivetrain swap, lowered, custom real leather interior and I'm still not done!
Dadd is offline   Reply With Quote
Old 05-11-2012, 12:38 PM   #3 (permalink)
cjfrehlich's Avatar
thanks, i plan on getting classic inlines aluminum head when i have the money. ill just leave the head as it is thanks!
