289 Low Compression on Two Cylinders - Vintage Mustang Forums
Old 05-10-2012, 08:50 PM   #1 (permalink)
Default 289 Low Compression on Two Cylinders
A couple of weeks ago, my 289 started running poorly practically overnight. One day, ran fine...next day, go out for breakfast, and can't hold idle at stoplights, etc. The carburetor is a 600 Holley. I figured it had to be a vacuum leak, and checked all over the intake, but no luck. Even switched out carburetors, but no change. I figured I'd check the compression, and six of the cylinders were at 175-180 on the gauge. However, cylinder 2 was at 120, and cylinder 5 was at 105. I squirted oil in the spark plug holes on these two cylinders, and the compression went up - 140 on #2, and 120 on #5. It appears it could be bad or worn rings, but overnight? I pulled the heads and checked the valves, and this is what I found. This is the intake valve from cylinder #5.
LeeFred is offline   Reply With Quote
Old 05-10-2012, 08:52 PM   #2 (permalink)
Default Continued...
In comparison, this is the intake valve from cylinder #6.
Old 05-10-2012, 08:55 PM   #3 (permalink)
Default Cylinder #2
Here are pics of the intake valve from cylinder #2.
Old 05-10-2012, 08:58 PM   #4 (permalink)
Default Cylinder #1 Comparison
In comparison to #2, here is the intake valve from cylinder #1
Old 05-11-2012, 11:36 AM   #5 (permalink)
Intake valve deposits. Really looks normal. But time to check the valve guides for wear. You might end up doing valve guides and a valve job. But, this isn't why the engine is running bad. There are other things to look into. Two fouled plugs also? Weak coil? Stuck piston rings? Worn cam lobes?.
Roddster
67 GT 350 (#0036)("Miss July" 2004) owned since 1971. And I still drive it...SAAC 29 Concours GOLD, Div II, MCA Concours Trailered Gold 2X,
Also: 67 GTA S code COUPE (under construction)
General Shelby and Mustang enthusiast, MCA certified Concours judge
Roddster is offline   Reply With Quote
Old 05-11-2012, 06:59 PM   #6 (permalink)
Roddster - the only plug that was fouled was the #2 plug, the others looked "normal" and alike. I pulled the pistons out of #2 and #5 - what would be the symptom of a stuck ring? They're moving freely now that the pistons are out of the block, and the pistons don't show any sign of crud buildup, scuffing, etc. The cylinder walls aren't scored or appear to be damaged in any way. Quite perplexing!
Old 06-19-2012, 12:00 AM   #7 (permalink)
Too late but it is an internal intake leak?
65 fstbk is offline   Reply With Quote
