power to gauges ? - Vintage Mustang Forums
Old 08-14-2012, 02:19 PM   #1 (permalink)
Default power to gauges ?
still a new to me mustang,,, and my first
anyhow,,, none of my gauges work and trying to figure why
i bought a new voltage regulator that i installed to the back of the gauge cluster with no difference
i just checked power to my gas gauge at the tank,,, test light goes on intermittently with a pulse type consistency
tried the temp sending unit with same results
also tried the wire on the oil pressure sending unit and could not get the test light to go on
1969 coupe with original 302
any ideas where my problem might be
i really dont like not having temp and oil pressure gauges
69Canuck is offline   Reply With Quote
Old 08-14-2012, 04:02 PM   #2 (permalink)
Franks68coupe's Avatar
pulse is correct. The oil pressure probably won't give you a reading if the engine isn't running (no pressure). try putting your multimeter across the posts on the back of the cluster. Might be missing a ground. Re-test your voltage regulator... wouldn't be the first bad part out of the box I've heard of. Can also try passing a current through the gauges themselves... unlikely, but they are all old and may just be broken.
Love me a Stang
68 coupe with a 351W and fmx
Mods: a lot... just ask if you're interested
07 gt
99 Gixxer 750 (When four wheels are too many)
Franks68coupe is offline   Reply With Quote
Old 11-20-2012, 12:41 PM   #3 (permalink)
Don3932's Avatar
How do you test the voltage regulator?
Don3932 is offline   Reply With Quote
Old 11-20-2012, 12:57 PM   #4 (permalink)
Blues Power's Avatar
gas test is OK as you found it. the IVR will give a pulsing IIRC 5-7 volts to that wire.
so your OK there
for the oil Pressure and temp turn the ign to on and ground those wirere for no more then 5 seconds or so. it should peg out each guage. EDIT: do them one at a time
if it does not then it sounds like the wiring, PCB or the guage it self is shot.
1970 Mach 1 San Jose built Dec 23 1969. Marti says 1 of 7. Purchased in 1987. Original family owner of the powertrain 351C 2v FMX.
1993 GT 11,000 miles, Built 2-12-93 Auto, 3:27 Axle, cloth, sunroof. Untouched except for rubber and battery, Purchased new 8-3-93. still has the factory windshield fluid and new car smell.
Blues Power is offline   Reply With Quote
