Toploader hurst shifter and shifter kit - Vintage Mustang Forums
post #1 of 14 (permalink) Old 08-30-2012, 01:10 PM Thread Starter
zhlange's Avatar
Trying to replace the shifter and shifter rails on my toploader. I am planning to use the hurst brand. Toploader pic and info I've included. The toploader came out from a mustang. The question: Is this the right part number for the parts #13-0072? You can't choose a knob though. I was going for the classic black knob. Thanks.
Daily driver money pit.
zhlange is offline
post #2 of 14 (permalink) Old 08-30-2012, 01:38 PM
silverblueBP's Avatar
Looks like the same shifter I have on my 66 w/ toploader.
-Mark-
1966 Mustang 2+2
"Money can't buy happiness, but it can buy a race car. And I've never been sad in a race car!"
silverblueBP is online now
post #3 of 14 (permalink) Old 08-30-2012, 01:43 PM Thread Starter
zhlange's Avatar
silverblue: Thanks for the info. I know mine is a 68. But did you have any problems with the kit (fit issues etc.). And is the product number correct?
PS: The tip of the shift rails are those custom made or part of the kit?
http://i560.photobucket.com/albums/s..._0110Large.jpg
zhlange is offline
post #4 of 14 (permalink) Old 08-30-2012, 03:15 PM
I had to add some spacers to mine to get it to shift smoothly.
'65 Coupe 351w - Page 8
ajzride is offline
post #5 of 14 (permalink) Old 08-30-2012, 07:39 PM Thread Starter
zhlange's Avatar
ohh man. its a 400 dollar system that doesn't work. i might as well use the old one.
zhlange is offline
post #6 of 14 (permalink) Old 08-30-2012, 09:37 PM
I have a 3 speed top loader with a hurst shifter. Had initial trouble getting linkage set right, as there are few pics and even worse instructions. Linkage is still loose and gets locked if I try a speed shift. I'll work on that this winter during rainy season. I'm not sure about PNs
Good luck on your install.
65 Convertible, 302, Front Disk, Red Exterior, Black Interior. 3 Speed Manual. P225/60R15 BF Goodrich, American Standard Wheels.
slhstang is offline
post #7 of 14 (permalink) Old 08-31-2012, 05:33 AM
I think you need this 3913180 Mustang Hurst Shifter Competition Plus With Knob 4-Speed 1965-1973 | CJ Pony Parts and this 3735587 Mustang Hurst Shifter Mounting Kit Competition Plus Toploader Big Block V8 1967-1969 | CJ Pony Parts
Once installed its a breeze to adjust. Insert the pin to make sure the shifter is in neutral, put the trans arms (levers) in neutral and adjust the rods. No big deal.
I think what you are calling "shift rails" are actually the shifter "rods". The "rails" are internal parts in the trans.
Joe
Past Mustangs: 66 Fastback 289/4spd, 2 65 Coupes with 289s, 66 Coupe 289/C4. All gone away!
Currently own:
1965 Mercury Comet Hardtop
289/Autolite 4100/4spd Toploader
1964 Ford Falcon convertible. 289/C4. PS, power disc brakes, power top
jmd66fb is offline
post #8 of 14 (permalink) Old 08-31-2012, 10:44 AM
65 coupe's Avatar
I have a Hurst 3 speed on my 65. I also have the orginal instructions that came in the kit. It's a Hurst Syncro/Loc # 290-6111 I got it new in the box old stock (1969) off Ebay. I had no problems with the install except I had to cut about 1/2" off one end of the shift rod after I had them adjusted to clear the e-brake lever. Shifts perfect like a Hurst should. I don't have access to a scaner but I could take a photo of the instructions and post them here for you if you think they might help.
65 Coupe
65 coupe is offline
post #9 of 14 (permalink) Old 08-31-2012, 01:18 PM Thread Starter
zhlange's Avatar
jmd: You're right. I was talking about the shifter rods. Sorry. Have you had any experience with the product? What is the big difference between the small block kit and the big block kit (other than the fact its say small block or big block application)? Something to do with mounting location? Also, is it a big difference (feel, performance, etc) between hurst and the original shifter kit (that i still have)? Thank you for the link.
zhlange is offline
post #10 of 14 (permalink) Old 08-31-2012, 03:24 PM
I have a Hurst shifter on my 65 Comet with Toploader 4 speed. I like the way it shifts and it feels absolutely solid. You cannot go wrong with a Hurst shifter.
I used a Hurst instead of the factory shifter because the 65 Comet factory 4 speed shifter is about impossible to find. The Hurst is available and replacement parts can be found. If you have the factory shifter disassemble and clean it up and use it. If it feels sloppy then get a Hurst.
BTW, disassemble a Hurst and a factory shifter and youll see why the Hurst is a performance upgrade.
Not sure the difference between big and small block shifters on the Mustang.
Joe
Currently own:
jmd66fb is offline
post #11 of 14 (permalink) Old 08-31-2012, 05:03 PM
Just an observation. My experience with Hurst shifters is limited to '71 to '73 cars. The shifter mechanism in your pictures seems to be rotated clockwise a considerable degree. The ones I have worked on, all had the levers to which the rods attach pointing straight down when in the neutral position. Are you sure the shifter is mounted correctly?
Don
PrecisionTrans is offline
post #12 of 14 (permalink) Old 08-31-2012, 05:13 PM Thread Starter
zhlange's Avatar
jmd66fb: Ok thanks. I will keep that in mind because everything is intact with my original shifter.
BTW, I ordered a rebuild kit from toploader heaven. It should arrive next week. Mark has been very accommodating so far. Kinda excited and scared of the unknown because I've never rebuilt any machinery before.
Also, there is a small chip/grind on one of the second gear teeth. Do you think I should replace it? It worked fine before I pulled it out.
zhlange is offline
post #13 of 14 (permalink) Old 08-31-2012, 05:40 PM
I added the heim end links myself. It makes for a very nice, smooth, solid shift. Gets rid of the slop associated with the stock plastic bushing with that spring clamp.
-Mark-
1966 Mustang 2+2
post #14 of 14 (permalink) Old 08-31-2012, 05:44 PM Thread Starter
zhlange's Avatar
silverblue: Thank you for sharing. Can I buy those in a regular auto shop? I'm planning to that upgrade. It looks more sturdy.
zhlange is offline
