Hello Everyone, What do I have to do to get the correct adjustment. Now when I depress the brake pedal, the fronts lock and the rears continue to spin (on a gravel road). I assume I need more braking at the rear. Thanks. ( '65 V8 Auto Conv w/front discs and rear drums)
No. You're done. You want the fronts to lock first. If the rears lock first, the back swings around and becomes the front, and you go backward off the road.
Amateur restorer. (Well, once in a while I have been paid for it)
I agree, the fronts should lock up first. Will the rear end swing around while the rear tires are locked up & the front wheels are not ? Seems strange that locked up tires will "pass" tires not locked up. Obviously, you will loose control regardless w/ either front or rear locking up. Dean
'66 Sprint 200 deluxe interior hardtop ( not a coupe ), owned since '84 as first car
'66 factory GT A code 4 speed fastback
No, if it were me, I'd do it until the fronts lock up and the rears just barely do (after the fronts, of course, if it's possible.. Might be so you can't get the rear to lock up without doing it first.. Haven't played with mine enough.
when you lock up the rears the back end wants to fishtail. i cannot explain the reason for this but when you lock up the rears and not the front you can spin out. a 180 degree turn is done by using the parking brake to lock up the rear wheels and turing the steering wheel about a 1/4 turn. i love do 180's especially on wet pavement at night when no cars are on the road.
I also think you should adjust so there's more rear braking- what I did was adjust until the rears started to lock first and then back off some (instructions should come with the valve as to how much- 1 turn ...). True you don't want the rears to ever lock first but you also want them to do some work. John
"If you need a new machine and you don't buy it, you pay for it without getting it." -Henry Ford
OT, but noticed your picture. I used to live about 2 miles from Elvis' birthplace in Tupelo. When were you there?
Steven
Hickory, NC
1966 Coupe
Replaced
Full floor pan
Firewall
Full cowl
Radiator support
Up next:
Shelby drop, 4 wheel drum to disc conversion, rebuild front suspension/steering, taillight panel, trunk floor,302 and AOD upgrade, wiring harnesses back in, and hopefully only patch panels on the quarters
E=MChuck Norris
Usually you want to adjust until the rears start to lock, then back off on the rear slightly.
This will keep the majority of the stopping on the front, but in a panic, all will have stopping. You do not want so much the rear skids in the rain, but you also want the back brakes functional.
This is the way I've set up all the hot rods I've built, and they have all stopped straight and true.
Tom
'69 Coupe, Built 306, 4-Speed, Matte Black..... Old School RestoMod...Coming Attractions: 408 Stroker...
'90 Mustang LX, Built 306, 5-speed, cage, Screaming Yellow....3/14/12 Currently Getting TWIN TURBOS (always a change to make).....
1938 Cough,cough, Chev. 1/2 ton Owner built "Street Gasser" truck..327, 461X, Hillborn...old school all the way...
A Custom HD RoadKing...and too many Vintage Sleds to count...
I know it seems counter-intuitive, but a 'locked-up' skidding tire will have less resistance (especially laterally), than a tire that has good traction with the ground.
This is why semi-trailers will tend to jack-knife when they lock up the rear trailer brakes. Anyone with a lot of experience driving large trucks has probably experienced this at some point. It is actually a very creeping feeling when you lock up the rear brakes on a large truck. You can actually sort of 'feel' it. And then you can see the trailer start to swing around in your mirrors. Hopefully you notice fast enough, get off the brakes and the trailer will fall back in line behind the tractor.
Same concept with our cars. Just a lot less dangerous.
mark
04 SVT Cobra, Torch Red (daily driver)
67 'vert 302,4spd,Red/Red (almost ready!)
67 Coupe 289,auto,black/black,deluxe (sold)
67 Coupe I6 to V8 conversion (sold)
The best way to set the brake bias is with a gauge on the front and back.
It's a bit of work, but a lot of piece of mind.
1200 psi on the front and 800 psi on the rear should work great for you.
You want the front about 15 to 20 precent more than the rear.
This is a great kit, but you need two kits to do it correctly.
You're just thinking too straight forward literally.
Think of it this way. Rainy day, you're coming around a tight turn and you suddenly have to brake. Of course you don't want anything to lock up. But if the rears are way ahead of the fronts, then they will give up traction and want to swing out. And the fact that the front has the majority of the weight due to the engine etc. makes that light rear end want to pivot around the center of that weight.
Now if the fronts lock it's no fun either, but those front brakes will be much more effective because of the weight of the engine adding to the tire traction.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
