'65 front suspension kit?? - Vintage Mustang Forums
Old 11-10-2012, 10:53 AM   #1 (permalink)
Default '65 front suspension kit??
Any recommendations regarding a front suspension kit? I am looking at replacing the control arms, springs, spring saddles, bushings, tie rods, etc, etc, and I see that CJ's has a complete kit for around $622. Anyone have any experience with this kit? I want to keep everything as stock as possible, but i am looking for any info others might have when they did the front end suspension.
Thanks.
edselflop is offline   Reply With Quote
Old 11-10-2012, 11:00 AM   #2 (permalink)
cmefly's Avatar
Thanks.
I would check out OPENTRACKER RACING for your front end.
cmefly is offline   Reply With Quote
Old 11-10-2012, 12:45 PM   #3 (permalink)
JonK's Avatar
Agree with above. If you plan on driving and keeping your car do it right the first time, get quality parts vs. repops. I learned the hard way and bought an 'all in one' kit 4yrs. ago. The LCA bushings slid in the arm allowing the arm to rub the inner mount metal/metal. The UCA bushings started unscrewing (marked them with a grease pen).
You can get Moog tie rods from most parts stores, I got mine from local O'Reillys, looked up part #, they got them from warehouse next day no charge, one thing I did right. For UCA look at John's Street uppers, he cleans up the casting, adjusts the shafts and welds a tab on the caps to keep them from loosening.
Opentracker Racing Products - Upper Control Arms
LCA get from John or anywhere that sells the Moog version, thicker casting with more reinforcement bends than the repops, I put them next to each other and could easily tell the difference and wt.
If you are going to drive the car more than once a month Johns roller spring perches are a good investment, they'll allow the suspension to react much faster/smoother than the stock rubber ones that cause bind and fight every movement of the suspension.
While you're doing the UCA do the Shelby/Arning 1" drop for better alignment and tire contact patch:
DazeCars, Shelby Drop, Klaus Arning drop, upper control arm drop, Falcon, Mustang, Cougar 60-70
This is a good suspension primer article to read first:
DazeCars, Suspension 101
Jon
"If it ain't broke, I haven't fixed it yet"
-Jon-
1967 Coupe 333ci CandyApple Red w/red int., AOD, 9" 3.50:1, Front PDB
'09 Warriors In Pink V6 w/glass roof - wife's Stang
JonK is offline   Reply With Quote
Old 11-10-2012, 03:43 PM   #4 (permalink)
Banned
Moog are very good quality components!
beechkid is offline   Reply With Quote
Old 11-10-2012, 04:29 PM   #5 (permalink)
Smitten's Avatar
Opentracker...
Steve
64 1/2 D code 5 speed Coupe
04 V-6 Coupe 5 speed
Plus 8 more that I no longer own!
Smitten is offline   Reply With Quote
Old 11-10-2012, 05:00 PM   #6 (permalink)
Grin
Jon
Absolutely! The problem with "kits" is they load you up with stuff either you don't need or want. This is an excellent time to modernize your suspension for today's driving. In addition, I'd recommend adjustable struts with rod end. Yeah, I know everybody's spending your money on what seems to be more money then you intended but this is one area where the extra expense is worth it! Shaun is a member owns Street or Track and makes some really nice parts. This is what I bought from him. I didn't intend on buying all this stuff but I don't regret it or have second thoughts, not for one second.
Tom
Rehab is for quiters!
Huskinhano is offline   Reply With Quote
Old 11-10-2012, 10:26 PM   #7 (permalink)
What kind of shocks ?
preaction is offline   Reply With Quote
Old 11-10-2012, 11:37 PM   #8 (permalink)
Banned
Shock Recommendations IMHO:
1) Koni- Excellent for racing applications- overpriced for street applications
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications. If you are running very stiff tires on the street (such as Bridgstone that are 100% steel belted or tires with profiles shorter than 50 series), these provide the extra give that you need for both comfort & stability
3) KYB- A very good shock for street/strip applications. If you are running a softer tires on the street (such as BFG that are a mix of steel & nylon belted or tires with profiles not shorter than 50 series), these provide the extra stiffness that you need for both comfort & stability. The Exel-G’s (formerly GR-2) are the equivalent to the Edelbrock IAS automatic adjusting units. Overall, stiffness between the Gas-a-just and the GR2’s are the same, the difference is the GR-2's valving which stiffens things up from a oem setting to that of the Gas-a-just units.. Best shock for the $/best price typically found at Performance Suspension Technologies (PST) and typically about 1/3 less than Bilstein.
4) Gabriel- A very nice good quality HD OEM replacement type unit.
Old 11-11-2012, 03:36 AM   #9 (permalink)
Opentracker(John) Street or Track (Shaun) or Maier Racing(Mike) Any of these guys can help you out and steer you in the right direction.
14CHARLI is offline   Reply With Quote
Old 11-11-2012, 10:12 AM   #10 (permalink)
If I am trying to stay with the original "stock" look, it appears that the Opentracker, and other "modern" systems, don't lend to that very well. I am trying to keep this car as original as possible, and it is NOT going to be a daily driver or track / performance car. I guess I should have stated this in my initial posting ......
I see another "stock - type" kit offered on eBay by Laurel Mtn Mustang. I am NOT trying to "cheap-out" on this, just really wanting to keep the stock setup.
What have others used to rebuild the front suspension, yet still maintaining originality?
Old 11-11-2012, 11:13 AM   #11 (permalink)
I'm a sort of stock guy myself,I do run better springs,shocks, larger sway bars and lately roller perches. That said I don't do kits. As stated you may wind up with stuff that you don't need. They also typically are comprised of lesser quality parts.I always piece my stuff together I get Moog arms and such, I usually look and special order them through places like advance auto, I know sounds hoky but hey I have to wait for the parts to come no matter what ,so I order the stuff online and take advantage of the promo codes and free shipping.
66HPGT is offline   Reply With Quote
Old 11-11-2012, 12:25 PM   #12 (permalink)
ravenblack's Avatar
When I redid the suspension in my 64 1/2, I used grab-a-track stuff from Mustangs Plus. They have a kit that includes UCAs, LCAs, bushings, perches, etc. Pretty reasonably priced and seem to be good quality. I did the suspension on mine probably 5 or 10 years ago and haven't had any problems.
Here's a link
Mustangsplus.com | Mustang Parts :: Suspension and Handling :: Suspension Rebuild Kits :: 1965-66 Grab-A-TrakŪ Performance Suspension Rebuild Kit
64 1/2 Raven Black Coupe
D code 289
C4 auto
3.00:1 open rear
Resto redo
ravenblack is offline   Reply With Quote
Old 11-11-2012, 02:06 PM   #13 (permalink)
Street or Track front coilover kit with race valved Bilsteins. Awwwe-some!
'65 A Code Coupe. 289, 10:1, Trick Flow TW 170 heads, Comp Cams XE266HR roller cam, T5Z spec, StreetorTrack front coilovers, Maier Racing leafs / SFC's / Panhard bar, Bilsteins, Steeroids rack and pinion, hydraulic clutch, 3.80 gears, Detroit Locker, 4 wheel discs.
'87 Foxbody AutoX C Prepared. Under the knife, again.
Check out the Action Video
65ACodeCoupe is offline   Reply With Quote
Old 11-11-2012, 02:42 PM   #14 (permalink)
I didn't buy a kit but did replace my wore out front end parts with stuff from cj pony. The customer service was good, the parts were as they said they would be. The price was really good. Things I didn't like: The most of the parts were made in 'china'. I don't know if it should matter but to me on a classic car I felt it kinda did. I also found the lower controls arms that I bought to replace were built a lot lighter than the origanals. I ended up reusing my Lowers and just replacing the ball joint. I didn't replace the front springs, but did the perches. I ordered there cj's cheap shocks and they're nothing I would want to take to the race track but have returned the car to it's stock handling. I'm happy with the way it handles. Does it have a little bump steer? Well yes, these cars always did. Is the front end a little soft? Yeah, that's the way these car were. Could the handling be improved, of coarse but it wouldn't feel or look like the stang's I rememeber.
gman is offline   Reply With Quote
Old 11-11-2012, 05:06 PM   #15 (permalink)
cmefly's Avatar
I am not sure what you really understand what you are looking at with OPENTRACKER. You can buy his upper stock style control arms and stock style lower arms, GT coil springs, Roller Perches if you can afford it. and his tie rods and Roller idler arm. All of these are the stock style parts. I would not buy the cheap parts from the mustang venders. If you are going to buy parts stick with MOOG and MCQUAY NORRIS not the cheap chinese suspension parts.
