Radiator Hose Help - Vintage Mustang Forums
post #1 of 6 (permalink) Old 11-12-2012, 02:20 PM Thread Starter
Alert Radiator Hose Help
Hello
I have my on going engine project in my 67 FastBack. I have a passenger side water pump outlet with a radiator that has the lower outlet on the driver side. Does anyone know of a lower hose to accomadate this connection? I would hate to change the water pump or radiator unless I have no other choice..
Thanks to all
Lewis
ArmyMustang67 is offline
post #2 of 6 (permalink) Old 11-12-2012, 05:52 PM
any radiator shop can switch sides of the bottom outlet. wes
mustang656man is offline
post #3 of 6 (permalink) Old 11-12-2012, 06:07 PM
ArmyMustang67,
Look at the 1970 Mustang I may be wrong, but I thought it had a lower hose that is on the driver side (Big Block maybe?).
I have a 65 that has a driver side lower hose because it is an early 5.0 (1983) but it does not have the reverse rotation. I just went to Autozone and asked if I could go in the back and look to find something close and I did, and cut it to fit.
If you do this then be sure to save the hose number incase you have to replace it later.
I would give you the number of my hose, but the radiators in a 67 are slightly larger and I'm not sure it would work.
Good Luck and don't give up looking!
mxg30
mxg30 is offline
post #4 of 6 (permalink) Old 11-12-2012, 09:37 PM Thread Starter
MXG30
I am willing to try it. The hose clamps will fix up the difference. I just dont want to take off the water pump or change the radiator out.
post #5 of 6 (permalink) Old 11-12-2012, 10:21 PM
22GT's Avatar
It would work. All 65-69 289/302/351 used the same lower radiator hose.
His problem is he has a 1970 radiator, (or maybe a 6 cylinder radiator) which had the outlet on the LH side.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #6 of 6 (permalink) Old 11-12-2012, 10:47 PM Thread Starter
22 GT, I know it wont work with the original type of hose. I made the mistake of putting a staggered radiator with the original style water pump. Some say I should have put a driver side water pump outlet. I know Scott Drake carries a chrome on his catalog.
