Transmission cooler and built in cooler? - Vintage Mustang Forums
Old 11-15-2012, 02:21 AM   #1 (permalink)
Default Transmission cooler and built in cooler?
I must have a brain cloud or something - I fitted my new aluminum radiator and transmission cooler today, but I've forgotten how to route the hoses so I can use the built in transmission cooler in the radiator AND the stand alone cooler.
Does anyone have a diagram?
Or should I just use the stand alone cooler and plug/forget about the built in cooler.
bassman2 is offline   Reply With Quote
Old 11-15-2012, 08:46 AM   #2 (permalink)
Tranny --> built in cooler on rad --> aftermarket cooler --> tranny
So, that being said.... All you need to do is find the output of the tranny and run that through the above pathway. Easy :-)
67 fastback
67 coupe (sold)
68 coupe (sold)
64.5 vert
roboticservo is offline   Reply With Quote
Old 11-15-2012, 09:42 PM   #3 (permalink)
what brand of radiator is that and model number thanks bobby
2009 11.50 OSBA Index Champion
2010 7.30 OSBA Index Champion
2011 7.30 OSBA Index Champion
1965x is offline   Reply With Quote
Old 11-15-2012, 09:59 PM   #4 (permalink)
22GT's Avatar
And in cold weather, the in-tank cooler becomes a heater, so you're not pumping molasses through the trans.
Amateur restorer. (Well, once in a while I have been paid for it)
22GT is offline   Reply With Quote
Old 11-15-2012, 10:36 PM   #5 (permalink)
sportsroof69's Avatar
Are you using a loose converter?
sportsroof69 is offline   Reply With Quote
Old 11-21-2012, 02:17 PM   #6 (permalink)
Its a Champion 3 row aluminum radiator - CC340B 20" bought from CJpony parts.
Old 11-21-2012, 02:19 PM   #7 (permalink)
Loose converter?
Old 11-21-2012, 02:57 PM   #8 (permalink)
bartl's Avatar
Front fitting is the outlet, rear is the return.
http://forums.vintage-mustang.com/signaturepics/sigpic19079_1.gif
6F09A 63A 8 26 09D 71 1 5
bartl is offline   Reply With Quote
