I'm looking to do a power steering upgrade as well as a tilt column upgrade in my 66. I'm a tall lanky guy so an extra inch or two will REALLY help me on the steering issue, and the old manual box is so burned out that I feel like I'm going to break part of the steering wheel trying to turn it sometimes.
What combo of power steering / tilt column parts do I need to make this work pretty effectively?
I'm trying to keep the budget on it somewhat under wraps. I don't need it to be a race winner, just a weekend cruiser. Power steering that is tight and comfortable would probably go a LONG way towards this.
__________________ "Natalie", '66 Coupe
Freshly Rebuilt 4-Speed w/ Hurst Performance Plus
289, Holley Carb, Edelbrock Intake and Water Pump, Tefba, Summit Direct Fit Rad
3.55 with Posi, Zoom Clutch
Next On the Agenda:
Interior - Replace floorpans (in progress), new carpet, tilt column, new steering wheel
Exterior/Body/Performance: Windshield (in progress), New cowl (in progress), weatherstripping, power steering
For openers is your steering box full of the correct grease and properly adjusted?
Next there's fairly easy ways to increase leg room by 2+ inches. Dunno what you mean by tall and lanky. I'm 6' 6", the seat mod is one of the first things I do on any car. The dealer did the mod on my 64 1/2 as part of delivery set up.
Tilt and power will easily exceed $1000. Hey on a new car that's a tune up plus shocks!
Get some cats and shop around,
Slim
My '64 1/2 vert. Ordered May '64. D code 4 speed, handling package, caspian blue, accent group, Ford blue manual top.
'68 vert. driver. Owned since '77. C code AT, AC, PS, P disc B, PT lime gold, standard black interior and top. NOS RF fender and left quarter.New top and folding glass.
+1 on steering box grease. Over time the original stuff turns into the consistency of clay. Shooting some new stuff in there while running the wheel back and forth from lock to lock (helps to jack the front wheels off the ground) to "mix" it back up can help a great deal. +2 on cutting down the seat riser to provide more head and knee room. IMHO the best tilt/power solution would be an Ididit column and Borgeson integral box.
Also there's a track mod discussed here at length (pun is intended) that adds 2+" rearward adjustment.
Thanks for the input guys but I still would really like power steering. So if anyone knows a good combo let me know
Next On the Agenda:
Does the Borges on mate up directly to the ididit or the stock column..?
Next On the Agenda:
I did exactly what you are asking... visit my site to see what I did... feel free to ask any questions... it was a learning process that was easier done than said as it turned out.... LOL
__________________ 1966 Mustang GT RestoMod Project: 307c.i.d.,Holly 600 4brrl, TrickFlow Heads, Power Disc Brakes, Integral Power & Tilt Steering, AOD, 9" 3.50 posi rear end & a bunch of other stuff.
Project start date 1999. Completion date... fagidaboudit!
On a 66, the steering shaft coming out of the box is 3 feet long. The steering wheel bolts directly to it Adding tilt or the borgeson means major cutting on the stock components or wholesale replacement.
__________________ Everybody has to start some place
Actually, the only cutting that is required is if you are NOT going with an Ididit tilt... then you only need to shorten the tube as Borgesen provides new shaft that is the correct spline to fit into their intregal power steering box... and as far as the difficulty in cutting the tube... one can use a hack saw if they're real careful and take their time to keep it straight... took me about 1/2 to cut and replace the tube/steering shaft assembly... then, of course, I yanked it to install the tilt... which was just as easy...
on a 1 to 5 level (5 being the hardest), i'd rate this a 2.5 for the average person if your car is stripped... 4 if you have to work around everything in place.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
