Boss 302 Trans Am Front Brake Cooling - Vintage Mustang Forums
Old 11-21-2012, 09:56 AM   #1 (permalink)
Default Boss 302 Trans Am Front Brake Cooling
Hi, All--
I am in the process of installing a Ford Racing 5.0L "Coyote" crate engine into my 70 Mustang coupe, and part of that process includes the installation of the Ford Racing Controls Pack, which includes an Airbox from a 2011 Mustang GT.
The Ford Racing instructions state that you must use that airbox, but even if I cut out an area in the right front apron and figure a way to mount it, there just isn't room.
So, I've got an airbox from a 2006 Mustang GT, and if I cut the bottom out of it, I think I can create a structure in the right front apron area to mount it.
Now--the question is, how to get cold air to it; since this is a 70 Mustang, I've looked at the fender extensions, and there are two screws that hold a little plastic plate in at the area where the 69 headlights were. The fender has no opening that corresponds to that area, but I was thinking that I could cut that part out and install some black screening in the fender extension to provide cold air.
My memory isn't what it used to be, but it seems like I remember that the Boss 302 Trans Am cars had done this and had ducts for front brake cooling that they used.
Does anybody know anything about this? Am I just imagining this, or was it done?
If it was done, does anybody have any pictures of this? Or, better yet, a location where I could purchase the ducting parts?
Any information or assistance would be greatly appreciated!
Thanks!
70 Coupe Resto-Mod with 98 Explorer EFI 5.0, AFR 165 heads, CompCams XE258HR, 70mm Edelbrock TB, controlled by A9M ECU & TwEECer R/T.
Fox-body radiator w/all front accessories, and GM F-body LS1 dual electric fans controlled by a SPAL PWM fan controller.
Patriot Clippster ceramic coated shorties, customized Magnaflow 2-1/2" kit w/SuperTurbo mufflers. 4R70W controlled by Baummanator TCS, 98 Mustang shifter.
Dakota Digital instruments, P/W, P/L, keyless entry, remote trunk release.
stonecoldtx is offline   Reply With Quote
Old 11-21-2012, 10:15 AM   #2 (permalink)
22GT's Avatar
Hmmmm…
Amateur restorer. (Well, once in a while I have been paid for it)
22GT is offline   Reply With Quote
Old 11-21-2012, 10:55 AM   #3 (permalink)
The BOSS 302 Registry
Roddster
67 GT 350 (#0036)("Miss July" 2004) owned since 1971. And I still drive it...SAAC 29 Concours GOLD, Div II, MCA Concours Trailered Gold 2X,
Also: 67 GTA S code COUPE (under construction)
General Shelby and Mustang enthusiast, MCA certified Concours judge
Roddster is offline   Reply With Quote
Old 11-22-2012, 09:19 AM   #4 (permalink)
Originally Posted by Roddster View Post
Thanks!
Well, it appears I was right about the cars having front brake ducting, but not about where they obtained the cold air . . . looks like it's coming from right behind the bumper, not from the fender extension.
Ah, well--guess I'll figure something out to make it work!
Old 11-22-2012, 10:20 AM   #5 (permalink)
You might be able to modify the brake ducting shown at the beginning of this thread The 1965-1968 Mustang vintage racing thread - Corner-Carvers Forums which can be purchased here "Cobra Automotive" brakes, suspensions & steering parts .
1966ford is offline   Reply With Quote
Old 11-22-2012, 10:34 AM   #6 (permalink)
22GT's Avatar
It doesn't matter much where the air enters the duct, it matters that the duct blows into the brake. The ambient pressure on a duct behind the valence panel is about the same as if you cut a hole through it. Having air forced into the brake, rather than simply swirling around the wheel, is what matters.
Old 11-22-2012, 10:37 AM   #7 (permalink)
Banned
My memory is not clear on that particular car but, it was very common to have cold air intakes (brakes & carb) placed just behind/slightly below the front apron...typically within 6" of the ground which is the coolest air temp
beechkid is offline   Reply With Quote
