Change of plans engine-wise - Vintage Mustang Forums
Old 11-21-2012, 12:49 PM   #1 (permalink)
wareagle's Avatar
Default Change of plans engine-wise
A good friend called me today and offered me a 289 he has in an old Scout FREE OF CHARGE... Said the last time he ran it it ran like a top... Looks like I'm in the market for a 9" rearend and 5 lug spindles...
Steven
Hickory, NC
1966 Coupe
Replaced
Full floor pan
Firewall
Full cowl
Radiator support
Up next:
Shelby drop, 4 wheel drum to disc conversion, rebuild front suspension/steering, taillight panel, trunk floor,302 and AOD upgrade, wiring harnesses back in, and hopefully only patch panels on the quarters
E=MChuck Norris
wareagle is offline   Reply With Quote
Old 11-21-2012, 12:54 PM   #2 (permalink)
qwk66's Avatar
What about the trans you were going to rebuild. Will that work with it?
66 Coupe - http://www.flickr.com/photos/22310759@N08/
qwk66 is offline   Reply With Quote
Old 11-21-2012, 12:56 PM   #3 (permalink)
wareagle's Avatar
As far as I know a C4 will work fine with a 289. But it does beg the question... Should I go with a T5
Steven
Hickory, NC
1966 Coupe
Replaced
Full floor pan
Firewall
Full cowl
Radiator support
Up next:
E=MChuck Norris
Old 11-21-2012, 01:03 PM   #4 (permalink)
That c4 should be fine. I had one in my 66 with a 302 and had no problems. I also have one in my 68 with a 289
tycooley is offline   Reply With Quote
Old 11-21-2012, 01:06 PM   #5 (permalink)
wareagle's Avatar
Guess it will all depend on whether I want a manual or auto...
Steven
Hickory, NC
1966 Coupe
Replaced
Full floor pan
Firewall
Full cowl
Radiator support
Up next:
E=MChuck Norris
Old 11-21-2012, 01:15 PM   #6 (permalink)
wareagle's Avatar
Will I need to change the bell housing on the C4 for a 289?
Steven
Hickory, NC
1966 Coupe
Replaced
Full floor pan
Firewall
Full cowl
Radiator support
Up next:
E=MChuck Norris
Old 11-21-2012, 02:00 PM   #7 (permalink)
if you have the c4 from inline 6 yes! I have one for 289 if you want to trade ... UPS charge is about $20 for shipping .. I bot it for my I6 and does not work but very good for 289 all cleaned now .. LMK
hughnews1 is offline   Reply With Quote
Old 11-21-2012, 04:08 PM   #8 (permalink)
65fastback6's Avatar
Oh, and here I thought you might hang in there with the six,
everybody has a V8 be different!
Kidding aside sounds like a good deal for you, besides if you leave
the six in people will give you a tough time and say you should put in a V8
65 Fastback 2+2 Rangoon red, red interior
6 cyl, AT, A/C, P.S., P.B.
13" 4 lug wheels with spinner wheel covers
MCA# 00945
Previously owned Mustangs:
6F07C,5F07T,5F09A,6F08A,
5F07C,3F03F,1F03H,3F03H,
1F04F,3F01L,8F03Y,9F03W,
84 SVO,86 SVO
65fastback6 is offline   Reply With Quote
Old 11-21-2012, 04:11 PM   #9 (permalink)
Yes, you will need a bellhousing for a V8, check first and see if the 289
has 5 bolt or 6 bolt for the bellhousing so you can get the correct one.
I believe the C4 289 version had extra clutches in it compared to the I-6
version so while you are rebuilding it you can upgrade it.
The torque converter is also different for a V8
MCA# 00945
84 SVO,86 SVO
Old 11-21-2012, 04:37 PM   #10 (permalink)
2manyhobbies's Avatar
Send a message via Skype™ to 2manyhobbies
+1, sorry.
Plenty of c4 trannies holding up to stout small blocks, and 8 inch rear ends too. Don't think you have to have a nine if you can find a deal for an 8. I actually have a cut down 9 sitting next to the car but will prolly not ever use it.
"LAZARUS"
Goodguys Younguys award winner TX-2000
MCA Grand National Pinnacle Award: Best Modified Driven, Sept 2012
Modified Mustang & Ford article: ?/2013
2 years of hard labor later
2manyhobbies is offline   Reply With Quote
Old 11-21-2012, 05:50 PM   #11 (permalink)
Theres a BW T-10 for sale in the classified for $300 which is a great price- I believe he also has a bellhousing for sale as well. I would get an eight inch rear end- there cheaper and easier to find and plenty strong enough for most applications. John
"If you need a new machine and you don't buy it, you pay for it without getting it." -Henry Ford
64.25 is offline   Reply With Quote
Old 11-21-2012, 06:01 PM   #12 (permalink)
Caper50's Avatar
Congrats on scoring the engine.
Brian
66 Mustang Coupe 289-2V under construction
Caper50 is offline   Reply With Quote
Old 11-23-2012, 11:21 AM   #13 (permalink)
wareagle's Avatar
Must be blind... I didn't see the tranny you mentioned.
Steven
Hickory, NC
1966 Coupe
Replaced
Full floor pan
Firewall
Full cowl
Radiator support
Up next:
E=MChuck Norris
Old 11-23-2012, 11:22 AM   #14 (permalink)
wareagle's Avatar
Thanks Brian.
Steven
Hickory, NC
1966 Coupe
Replaced
Full floor pan
Firewall
Full cowl
Radiator support
Up next:
E=MChuck Norris
Old 11-23-2012, 12:11 PM   #15 (permalink)
Default V/8 Conversion
Changing an I6 to a V8 will involve a lot more than your transmission. The rear end will need to be changed, 5-lug wheels front and back, front end changes as well. You might want to sit down and list out all the mods required before you get started.
Briarpatch is offline   Reply With Quote
