Electric fuel pump pre-filter? - Vintage Mustang Forums
Old 11-25-2012, 12:20 PM   #1 (permalink)
Default Electric fuel pump pre-filter?
Well my holley blue started leaking from the vent holes & after some Internet research it was laid to rest. I picked up a holly HD 125 because of its quieter gerotor design. The instructions recommend a 80-100 micron pre-filter, but I'm having issues getting everything mounted and below the fuel level. My old pump was mounted between the tank and differential with no pre-filter. Can anyone running a pre-filter and similar pump share some pictures of their set up? Or should I forgo the pre-filter? My original holley blue set-up ran since 2002 with no problems. Thanks for any help.
sanch052 is offline   Reply With Quote
Old 11-25-2012, 02:44 PM   #2 (permalink)
Afrett,
Your set up is how I was planning on running mine, but I'm having trouble finding a similar size pre-filter that is 100 microns. Is yours a Mallory? If so I could only find a 40 micron which would void the warranty.
Cool sending unit by the way is that a -8 return line.
Old 11-25-2012, 02:59 PM   #3 (permalink)
bartl's Avatar
Holley 100 micron, 100gph fuel filter
http://forums.vintage-mustang.com/signaturepics/sigpic19079_1.gif
6F09A 63A 8 26 09D 71 1 5
bartl is offline   Reply With Quote
Old 11-25-2012, 07:33 PM   #4 (permalink)
ozarks06's Avatar
Originally Posted by sanch052 View Post
Afrett,
The 40 micron filter will filter more dirt than the 100 micron (40 micron particles are smaller than 100 micron particles). The only way it might cause problems is if it got clogged and starved the pump and it overheated.
Plain Jane 65 Coupe - Scary fast (at least that's what my wife says). (SOLD 10/2012)
Feature Car in December 2010 StreetScene (the magazine of the National Street Rod Assoc)
ozarks06 is offline   Reply With Quote
Old 11-25-2012, 11:21 PM   #5 (permalink)
Originally Posted by bartl View Post
I was looking at that filter, but I didn't like the o-ring -6 fittings. Seems like one more rubber potential leak point. I did want the similar holley hd version that comes in the 3/8 npt, but their back ordered till jan. I went with the larger 175gph version, but its to big for me application.
Old 11-25-2012, 11:31 PM   #6 (permalink)
Ozarks06,
According to Aeromotive & Holley anything lower than 80 microns as a pre-filter affects the gravity feed to the pump. 40 and lower should go after the pump. Check out the link good info
Pre-Pump Fuel Filtration|Aeromotive
