disc brake questions - Vintage Mustang Forums
Old 11-25-2012, 03:33 PM   #1 (permalink)
Default disc brake questions
67 Vert that originally came with power discs.
SSBC billet 4 piston calipers on the front and we are leaning towards getting a 9 inch rear with discs off of ebay:
Complete 9" Rearend - 1967-1970 Ford Mustang - 9 Inch | eBay
What should I do for lines and booster/MC?
Do I need to run a porp. valve?
Do I eliminated the stock distribution block?
Bend my own lines or start with a 67 kit?
Thanks!
merfsiu is offline   Reply With Quote
Old 11-25-2012, 03:49 PM   #2 (permalink)
Yes, All Front Disc will run a P Valve.----Oh Yes next Question, I GOT Rear Disc, Fronts don't know that, Weight tranfer is same, Rear Disc/Rear Drum, makes no difference.
Obvious you are not doing a point car, just a good driver, YES, keep the stock distribution block, plumb a P valve in the REAR cirucuit--Where ever you want, again the fronts don't care.
Yes, get generic lines, a tube bend, a case of Bud, HAVE FUN!
Dan @ Chockostang
CHOCK is offline   Reply With Quote
