Base or Shelby parts - Vintage Mustang Forums
Old 11-27-2012, 12:09 AM   #1 (permalink)
4mustangs's Avatar
Default Base or Shelby parts
I was looking online for LCA's for a '65 coupe with I6 when I came across a Shelby version. It looks stronger than the stock part. It's only $24 more. Anyone ever use them, if so are they interchangeable?
Ron
-----REMEMBER-----
BUY AMERICAN, YOUR LIFESTYLE DEPENDS ON IT!
4mustangs is offline   Reply With Quote
Old 11-27-2012, 02:14 AM   #2 (permalink)
bartl's Avatar
Don't know about a "Shelby" LCA, but the one on the right with the pressed in ball joint is what I had in my '65 K-code GT.
http://forums.vintage-mustang.com/signaturepics/sigpic19079_1.gif
6F09A 63A 8 26 09D 71 1 5
bartl is offline   Reply With Quote
Old 11-27-2012, 02:34 AM   #3 (permalink)
supershifter2's Avatar
i use MOOG lca cause they are the best. for hipo use i use a sperical bearing in place of the rubber bushing.
supershifter2™ < !
supershifter2 is offline   Reply With Quote
Old 11-27-2012, 06:25 AM   #4 (permalink)
22GT's Avatar
Neither is correct. The pressed-in ball hadn't even been invented. The Shelby and 6 cylinder car had the same control arms.
64-66 LWR CNTRL ARM-concourse 64-66 Lower Control Arm, concourse Detail Page
Amateur restorer. (Well, once in a while I have been paid for it)
22GT is offline   Reply With Quote
Old 11-27-2012, 08:02 AM   #5 (permalink)
bartl's Avatar
I don't know when, exactly, it was "invented", but I had a pressed in one separate from the LCA after whacking a giant pothole in the mid-seventies. Both LCA's had the pressed BJ and, to my knowledge, were both original to my San Jose hardtop.
Old 11-27-2012, 09:08 AM   #6 (permalink)
4mustangs's Avatar
I'm not looking for stock, I'm looking for better while staying in a reasonable price range for a daily driver.
Ron
Ron
-----REMEMBER-----
Old 11-27-2012, 09:12 AM   #7 (permalink)
4mustangs's Avatar
These are both MOOG off the Summit racing site.
Ron
Ron
-----REMEMBER-----
Old 11-27-2012, 09:18 AM   #8 (permalink)
4mustangs's Avatar
Then these two MOOG parts are either an attempt to improve over the original or to reduce cost. which one of these is the question.
Ron
Ron
-----REMEMBER-----
Old 11-27-2012, 09:22 AM   #9 (permalink)
4mustangs's Avatar
We don't have potholes in Virginia Beach and when I am out of town I try to avoid them.
Ron
-----REMEMBER-----
Old 11-27-2012, 09:50 AM   #10 (permalink)
I did see an article on welding a plate to the bottom of the LCA to stiffen it up. Not original, but does it do the trick?
1995 GT convertible - Laser Red
1995 GT convertible - Black (Son's ride)
1966 GT Fastback under restoration- Code T Red
with White LeMans stripes.
ScottsGT is offline   Reply With Quote
Old 11-27-2012, 10:03 AM   #11 (permalink)
bartl's Avatar
Exactly! There are a number of ways to stiffen up the OE uppers and lowers. I think Branda or CJ's offers a kit that comes with a plate already cut and some hardware. Also, as SuperShifter mentioned, substituting a spherical bearing for the bushing helps.
Old 11-27-2012, 10:22 AM   #12 (permalink)
What is the deficiency of the stock LCA? Wouldn't the money be better spent elsewhere? ie 1" drop.
oldpaint is offline   Reply With Quote
Old 11-27-2012, 10:24 AM   #13 (permalink)
4mustangs's Avatar
I've been thinking about that but pretty much have decided not to do because of so many comments about the stock configuration being more than enough for street use. When I found this Shelby part I just figured for a few bucks more, stronger is better.
[][][][][][][][][][]UPDATE:[][][][][][][][][][]
I called Summit tech support and the tech looked the Shelby part up in the MOOG catalog and it is for '67 only on both Shelby and Base model,there site is wrong,. Maybe useful for the guys with '67's. I will try to get more info direct from MOOG and post it but I can't imagine a '67 LCA fitting a '65.
Ron
Ron
-----REMEMBER-----
Old 11-27-2012, 10:38 AM   #14 (permalink)
silverblueBP's Avatar
John at ORP makes some really nice suspension parts!
Opentracker Racing Products - Products Page
-Mark-
66 A code 2+2
CarDomain site
4 Paws -n- A Tale Pet Supplies
silverblueBP is offline   Reply With Quote
Old 11-27-2012, 11:02 AM   #15 (permalink)
4mustangs's Avatar
Originally Posted by oldpaint View Post
What is the deficiency of the stock LCA? Read bartl's post on potholes.
Wouldn't the money be better spent elsewhere? ie 1" drop.I don't due cheap on a car I'm fixing up for my grandson. Did the drop for $0. I guess if you had no tools it would cost you.
Ron
Ron
-----REMEMBER-----
