See two versions of them on CJPP...one is a Scott Drake, the other doesn't seem to have a brand name attached to it.
Are these worth a darn? I seem to remember reading something about people's gas caps not venting properly or something....
__________________ "Natalie", '66 Coupe
Freshly Rebuilt 4-Speed w/ Hurst Performance Plus
289, Holley Carb, Edelbrock Intake and Water Pump, Tefba, Summit Direct Fit Rad
3.55 with Posi, Zoom Clutch
Next On the Agenda:
Interior - Replace floorpans (in progress), new carpet, tilt column, new steering wheel
Exterior/Body/Performance: Windshield (in progress), New cowl (in progress), weatherstripping, power steering
__________________ Bay Area Mustang Association
President BAMA 2012-
'65 Fastback Mustang Monthly March 2013 NorCal Forum
Before
After
If you can read this, thank a teacher. Since it's in English, thank a soldier
Replaced
Full floor pan
Firewall
Full cowl
Radiator support
Up next:
Shelby drop, 4 wheel drum to disc conversion, rebuild front suspension/steering, taillight panel, trunk floor,302 and AOD upgrade, wiring harnesses back in, and hopefully only patch panels on the quarters
E=MChuck Norris
Try a search. I believe there was a post about a problem with some of the Scott Drake units, but one of their reps were looking into it and may have identified the defective units.
Next On the Agenda:
Are gas caps on vintage Mustangs not supposed to be tight enough to prevent fuel leaking out if going up-hill with a full tank? I live on a hill and noticed fuel leaking out, so I've been looking for a new gas cap. Did I wasted my time then?
Dogface GI
1965 200ci I6 Hard-top,
Black & Wimbeldon-White and Awesome Car All-Over!
5F07T381000
I had a problem with one. But SD and Virginia Mustang took care of it. No problems with second one. But I dont fill it up and park in the sun anymore just in case.haha.
Kevin
1965 Fastback-Scat 331, Dart heads, FPA headers, Air Gap intake, 650 Ultra DP, Cobra pan, Lunati VooDoo cam 61003, C-4, 10 inch converter, Reverse manual valve body,Detroit Truetracw/3.50s, subframe connectors.
1968 S-code Torino Fastback= project
1966 A-code Mustang coupe=Basket case not sure what to do with it used some parts for the fastback.
I had one of the defective Drake caps, my local vendor exchanged it with no problem. You'll know if you end up with one, since it's assembled backwards- it'll fit loose enough that it'll threaten to fall off if you hit a bump.
It's a very nice looking piece, and once it was exchanged I couldn't be happier with it.
I use a 71 Mach 1 cap repop, I don't think it vents now that I think about it.
"LAZARUS"
Goodguys Younguys award winner TX-2000
MCA Grand National Pinnacle Award: Best Modified Driven, Sept 2012
Modified Mustang & Ford article: ?/2013
2 years of hard labor later
1995 GT convertible - Laser Red
1995 GT convertible - Black (Son's ride)
1966 GT Fastback under restoration- Code T Red
with White LeMans stripes.
I had a SD cap on my 65 and after 3 years the plastic got all spider-web cracked and moisture got behind it.
__________________ Plain Jane 65 Coupe - Scary fast (at least that's what my wife says). (SOLD 10/2012)
Feature Car in December 2010 StreetScene (the magazine of the National Street Rod Assoc)
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
