New motor bogging down - not sure what to check with Edelbrock carb - Vintage Mustang Forums
Old 11-28-2012, 05:51 PM   #1 (permalink)
DesertCoupe5.O's Avatar
Default New motor bogging down - not sure what to check with Edelbrock carb
While my car was in the body shop I did new HCI on the motor with Trick Flow heads and a Comp XE266HR-12 cam. It idles and revs fine, but bogs under low RPM (1000-3000 or so) load when I give it gas. It seems to clean up at higher RPMs, but the power isn't there like it should be. I opened the carb and cleaned all the jets twice and blew air through everything. Vacuum at idle is ~15 inches. When I give it part throttle at 30mph or so it feels like I'm running on 7 cylinders. I've only driven about ten miles. #1 spark plug looks new. Could the new HCI cause my carb to need new calibration? Any help would be appreciated - this is really my first time trying to mess with a carb other than on small engines. It was running great 8 months ago with a stock HO 5.0 top end.
68 Coupe - Built Roller 302, Built AOD, 8.8 w/4 wheel discs
DesertCoupe5.O is offline   Reply With Quote
Old 11-28-2012, 06:36 PM   #2 (permalink)
Hwyman's Avatar
When you first open the throttle, especially at low rpm, you lose vacuum and the air doesn't suck fuel out of the carb. as well. The accelerator pump compensates for this by shooting fuel in to the carb. until rpm and vacuum increase. Check the accelerator pump to see if it is shooting gas in to the carb. when you open the throttle. You can also use another hole on the carb. to make the pump deliver more gas.
Hwyman is offline   Reply With Quote
Old 11-28-2012, 07:16 PM   #3 (permalink)
09Frank65's Avatar
1. What is your vacuum in drive with brake applied? (Safely!)
2. With the car in drive with the brake applied check to see if your step-up pistons are in the down position. You can slide the cover around just enough to see if the piston is up or down. If the piston is up the metering rods will be in the narrow portion of the rods causing a rich condition.
3. What torque converter stall are you running? Depending on cam specs you may be losing some torque until your RPM gets up into the power band of your combo with a stock converter.
Just some thoughts from my own experiences. If I understand correctly this is not just an off-idle transition issue but sustained at low rpms. If it is just an off-idle stumble or hesitation the other poster may be right with adjusting the accelerator pump linkage.
One other thought on edit is timing. You may want to bump your initial timing up a bit as well and then reset your idle speed accordingly.
1965 Mustang Coupe
1962 Falcon Tudor (sold)
2009 Mustang GT Glassroof
My Webpage
09Frank65 is offline   Reply With Quote
Old 11-28-2012, 07:38 PM   #4 (permalink)
I haven't measured vacuum in D, but I suppose I can have a look at the step-ups and see what they're doing. I'm running a 2500 stall - it's not that it's low torque, it sputters and feels like it's missing. The accelerator pump is working, and I've tried it in all three holes.
Old 11-28-2012, 08:14 PM   #5 (permalink)
2manyhobbies's Avatar
Send a message via Skype™ to 2manyhobbies
What are the specs on your cam? If its pretty radical it will feel weak until it actually gets into its powerband. Mine doesn't really wake up till about 2500rpm.
"LAZARUS"
Goodguys Younguys award winner TX-2000
MCA Grand National Pinnacle Award: Best Modified Driven, Sept 2012
Modified Mustang & Ford article: ?/2013
2 years of hard labor later
2manyhobbies is offline   Reply With Quote
Old 11-28-2012, 08:28 PM   #6 (permalink)
Just a shot in the dark but how's your fuel pressure?
evoasis is offline   Reply With Quote
Old 11-28-2012, 09:16 PM   #7 (permalink)
It's mild - it's 216/224 at .050", and I'm using a 2500 stall converter.
35-514-8 - Xtreme Energy? Hydraulic Roller Camshafts, Computer compatible (E.F.I.) with O.E. hydraulic roller cams 1985-95
Again, it's not weak, it's sputtering and feels like it's missing a spark plug or two.
Fuel pressure sits at 6 psi, but I can't see the gauge when driving.
Old 11-28-2012, 11:08 PM   #8 (permalink)
Which model E carb do you have? The electric choke version is jetted quite a bit leaner. I have a E carb on my tired 302 and it was way too lean. Get yourself a tuning kit and fatten it up. The manual is great in explaining how the carb works and how to tune it.
Tom
Rehab is for quiters!
Huskinhano is offline   Reply With Quote
Old 11-29-2012, 12:33 AM   #9 (permalink)
It's possible the secondaries are opening too soon and can cause it to bog down but shouldn't cause a misfire unless its overpowering your ignition system. I wouldn't expect you to be running a points dizzy but at least some sort of electrical system with that we up right?
"LAZARUS"
Old 11-29-2012, 01:02 AM   #10 (permalink)
GT350R Klone's Avatar
What is the initial timing and advance? Have you tried advancing it to see if it gets rid of the low end bog?
GT350R Klone is offline   Reply With Quote
Old 11-29-2012, 09:30 AM   #11 (permalink)
Timing is right around 10*, when I rev it advances close to 30. Where should it advance to?
Old 11-29-2012, 10:51 AM   #12 (permalink)
Initial is to the book, total may be low 4-6 degrees, but shouldn't be causing your issue. I would however try it at 12, 14 initial and see if there is any change. It may not be the answer, but it costs nothing to do.
I learned from an old timer mechanic to throw away the timing light. His thoughts were that once an engine is old or modified, that the initial timing marks are probably not reading right or not correct for the car. He showed me to hook a vacuum gauge to the manifold and change the timing at idle until max vacuum, then back off 1 1/2. It is the only way I have adjusted timing since and has worked for me.
Old 11-29-2012, 09:01 PM   #13 (permalink)
09Frank65's Avatar
I am at 16 initial, 36 total with XE274H cam.
If you have a tach in the car, see at what RPM it stops sputtering. It'll be easier if you keep it in one gear, i.e. second or third, whichever covers the RPM range best.
Then, back in the garage, see what the advance is at that magical spot, raise the idle speed to that setting and check advance with your timing light (which obviously will require a timing light with an advance knob).
That should give you an idea where you stand and whether it is advance related.
OR you could just do what I did and keep bumping it up until it ran nice and make sure it is not detonating...
1965 Mustang Coupe
My Webpage
Old 12-03-2012, 08:20 PM   #14 (permalink)
It's a 1405 and it was tuned for emissions in phoenix (1500 ft) a couple years ago and now I'm at 400 ft. I have a tune kit coming for it.
Old 12-03-2012, 10:27 PM   #15 (permalink)
1969sag's Avatar
This is just a suggestion.
Check your trans kick down cable, or TV cable.
I had a similar problem with my MSD. The advance curve springs were to heavy, causing the car to bog, and hesitate. I swapped out different, lighter springs, then retuned the carb, and reset the timing. Never had the problem again.
Joe in Detroit
1969 Sports Roof (SAG = Sports Appearance Group) 1 of 5k+
1966 Ranchero Deluxe 1 of only 10k made.
"what you've just said is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul."
MOVIE: Billy Madison
1969sag is offline   Reply With Quote
