Well, work on Ms. Jane has mostly come to a standstill these past few months because I've been so busy with school. But I asked my Dad for one Christmas gift: a prototype of the custom center console I've been wanting him to build. I've installed a center-mount emergency brake and wanted something to make the center hump look more tied together and the e-brake more natural. So here's what we've got so far! (And by we, I mean him, because I have had no involvement in the building of this
Overview of the whole console. Done similar to '68 Shelby styling.
Features of this part:
-Small strip of LED lights under the 'hood' created at the very top for extra courtesy lighting
-Row of 3-4 toggle switches in the very back for use in... well, whatever I can find to use them for! you can always use more switches
-Coin tray / junk tray at the bottom underneath the same hood - just using a piece of square trim to divide it off from the rest of the floor of the console, as seen
-Shift hole will be larger
-Floor contoured to surface of trans tunnel
-Hole cut out for perfect emergency brake clearance and not a bit more
-Center compartment, built to optimal arm height
-Rear courtesy lights around back from original '66 console will be retained
-Compartment may be lockable (
TBD)
-Compartment contoured around maximum throw of e-brake for the most space and heat reduction from anything that could come up through the small hole in the floor
Removable side cup holder. I wanted to retain the straight lines of the original console but also wanted the option of having cupholders if necessary - thus, removable holder! Engineering on that still not quite done because it needs to look natural on the console if attached. Attachment method is also a problem due to the extra jut of the trans hump on that side.
I'm taking a few basic metal classes this winter break to see what I can come up with, but ideally the floor of the console will be one piece of metal that has been milled to have the original '66 factory design (center polished ridges) and then bent to fit the console. Everything but the center polished ridges will be painted with a black camera-case texture like the one from factory if I can find a paint good enough. The sides will be upholstered in vinyl.
One problem that we're running into is finding a metal that is strong but fairly thin for use in the bottom of the console. Shot myself in the foot by installing the e-brake so low to the transmission tunnel that it's hard to get the proper amount of clearance for it. Whoops.
Anyways, just wanted to share the progress with you guys! Questions / comments / advice / ideas always appreciated
Calamity Jane aka "The Maybe-Not-So-Evil B$*&#"
1966 Fastback
289 v8, Powerjection III EFI, mild cam
4-speed, 3.25 9" rear
Power disc brakes, Unisteer power R&P
Pertronix ignition, RetroSound Model One radio, Classic Auto Air A/C, etc...
Three years of work for three days of perfection. This pony WILL get back out on the road and it WILL reliably take me where I want to go... and it will always, always keep me safe.
