Also, there is only ONE way to get experience, and that is to DO IT!
I guess every single professional out there at one time was inexperienced as I don't think anyone was born with the knowledge on how to build an engine.
Read everything you can on building an engine. Get a photobucket account, and post pics with your questions that you might need to ask on the forums.
I built my first engine by only reading a Chilton book on my car, and a Ford Performance book. There wasn't an internet back then so all I had to go on was info from other engine builders in the area.
I would still recommend building an engine from one that is posted on the net or a magazine article as being inexperienced its easy to over do things like cams, CR, etc, and end up with an expensive PIG, that won't out run a stock engine.
Also, buy a 351w, as when you have the need for more HP you will have a better platform vs a 302/5.0l until you have the $$ to go to an aftermarket block.
With the internet, and I would be there is some good video on Youtube, you will be set.
Horsepower TV's Pro-touring Pony 65 fastback/431w, 66 Shelby resto theme/393 paxton, 67 Eleanor 540fe/Procharger F1R, 66 shelby theme {wifes car, 347/paxton}
"People make grand plans for life as it passes them by"
