Clear Coating Parts - Vintage Mustang Forums
post #1 of 7 (permalink) Old 12-13-2012, 05:37 PM Thread Starter
sessayan's Avatar
Clear Coating Parts
So I always read in threads that folks would clear coat bolts or screws before they put them back on cars.
And I know this is super basic but is that as simple as buying a can of this:
http://www.amazon.com/VHT-SP515-Quick-Acrylic-Enamel/dp/B000CPCRJK/ref=sr_1_1?ie=UTF8&qid=1355438109&sr=8-1&keywords=clear+coat
and spraying the parts before you install them ?
Steve E.
1965 Wimbledon White Vert.
T5, FiTech EFI, Borgeson Power Steering ,Ididit tilt, Street or track 4 wheel disc, coil overs, 3 link rear, 3G alternator, Custom sound system
sessayan is offline
post #2 of 7 (permalink) Old 12-13-2012, 05:58 PM
69mach351W's Avatar
You can use VHT or about any clear coat.....Then after installation, I went back over(touch up) with clear Testors modelers clear with a modelers brush. My brackets, bolts,etc, have been done over 10 years now with no problems.
69mach351W is offline
post #3 of 7 (permalink) Old 12-13-2012, 06:00 PM Thread Starter
sessayan's Avatar
Thanks, I ordered a bunch.
Steve E.
sessayan is offline
post #4 of 7 (permalink) Old 12-13-2012, 06:07 PM
Idaho Stanger's Avatar
Yea, I use an over the counter rattle can of semi-gloss or flat clear coat. Only tip I have to offer is watch up for excessive build up on the threads as that can make re-installation difficult. Touching up with a paint brush with c.caot sprayed into cup works great after install.
'Genny' 1964 1/2 coupe Cascade Green
'Jessie' 1966 coupe Arcadian Blue
Idaho Stanger is offline
post #5 of 7 (permalink) Old 12-13-2012, 08:46 PM
Wire brush (power is best) and only spray the heads! Idaho Stranger is spot on
as to torque tension problems if you spray the threads, they will never rust any way.
I sometimes do an old detailers trick, spray paint on a 4x4 piece of aluminum and brush paint the heads, then your socket wont knock your coating off.
Leon Narozny is offline
post #6 of 7 (permalink) Old 12-13-2012, 10:44 PM
I've been using rattle can clear coat for all my restored/cleaned up bolts as well. I use various flat scrap cardboard pieces with a bunch of different sized holes to pop the bolts through so I only coat the heads.
1967 Mustang Fastback "Sally"
Ponyboychris is offline
post #7 of 7 (permalink) Old 12-14-2012, 08:45 AM
dzahm's Avatar
x 1 on the cardboard trick, keep the heads up high enough to allow the clear to coat the sides of the head. Eastwood has a "diamond clear" that I have used- it works well.
dzahm is offline
